Brake shaking
Old Apr 12, 2006 | 07:50 PM
EdgeVetto's Avatar
Brake shaking
I just bought my 96 GXE, and it was sitting in a driveway for about 6 months. When I use the brakes, they shake like a mother****er, and it's really annoying. Also, my alignment seems to be off when I go ~80 MPH, are these two things related? Is there something I can do about the brakes (I'm gonna get the tires realigned in a few days)?
Someone said that I should just replace the pads and hope for the best, any thoughts?
Old Apr 12, 2006 | 08:12 PM
kil2board's Avatar
my car did the same thing. i did alot of highway driving and one day they lockedd up and then just failed. turned out my pads were worn pretty bad and there were heat spots on my rotors, which is really dangerous. definitely do new pads, but see if you can have your rotors cut. i put HAWK carbon brake pads on the fronts, and did slotted rotors. that solved my problem completely.
IMO i would spend the extra $ and get slotted rotors for the front. they're incredible for highway driving.
Old Apr 12, 2006 | 08:22 PM
EdgeVetto's Avatar
think that'll solve the high speed vibrations too?
Old Apr 12, 2006 | 11:39 PM
jaep0913's Avatar
my brakes seems to be shaking sometimes too when i press it hard while going fast...
Old Apr 13, 2006 | 01:03 AM
Trajiksmax's Avatar
Proud Maxima Owner
New Rotors, New Pads, Balance Wheels, Front Alignment. I would start there if the vibrating persists could be a suspension related issue.
Old Apr 13, 2006 | 01:29 AM
VIP Maxima
your rotors are warped.
Old Apr 13, 2006 | 02:05 AM
86maxima96's Avatar
I Broke OT
beat me to it. that is most likely the case. happened to my max as well after it sat for a while
Old Apr 13, 2006 | 04:28 AM
EdgeVetto's Avatar
alright thanks alot
Old Apr 13, 2006 | 09:38 PM
kil2board's Avatar
yea...it should. as stated by previous org members, your rotors are warped(as were mine...kinda forgot to mention that
to answer your question yea it should. i do atleast 88-90 on my commute to work on the open stretches of 95 up here in new england and i havent had a hard braking problem since i had brakes done.
Old Apr 13, 2006 | 09:41 PM
99grnmaxgxe's Avatar
My driver side rotor is warped too, shakes like a b!tch when going fast. I wonder if I change it, will the pad need to be changed too?
Old Apr 13, 2006 | 09:47 PM
maximaman10's Avatar
You need to redo your front breaks and have the front rotors turned. It sounds like you front rotors are warped. That is what is making it shake like that.
Apr 16, 2020 05:15 AM
Need help
23
Oct 2, 2015 08:56 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
dshinn
Sep 26, 2015 08:07 PM
