Anyone Have A Funtional Hood Scoop????
Old Apr 17, 2006 | 11:15 AM
  #81
tavarish's Avatar
fwd gone rwd cr00
Originally Posted by nismos14
Could've done it without the hood scoop like Nismo
not with the motordyne plenum spacer.
Old Apr 17, 2006 | 11:17 AM
  #82
Caracicatriz's Avatar
What was that?
Originally Posted by DR-Max
To prove that he has no clue what he's talking about, he called it chemistry instead of physics. What does chemistry have to do with airflow? And for anything to develop pressure, it would have to be completely sealed. The engine bay is not a sealed compartment.
It's actually physical chemistry. More physics though. I took a class last year with problems just like this, only it was steam going into pipes.
Old Apr 17, 2006 | 12:07 PM
  #83
vsamoylov
yes that is true but then a spacer wont fit.
Old Apr 17, 2006 | 12:18 PM
  #84
nismos14's Avatar
§è~® f®ÈÄk
Ahh so did you put the plenum spacer on already?
Old Apr 17, 2006 | 12:20 PM
  #85
vsamoylov
not yet. headers are my next priority as well as some rubber
Old Apr 17, 2006 | 12:26 PM
  #86
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
i need to do a scoop on my right side, I think gettimg some more cold air into the turbo can never hurt, just afraid of the rain
Old Apr 17, 2006 | 01:07 PM
  #87
tavarish's Avatar
fwd gone rwd cr00
rain is a big question for me, as I would know how to route the opening so the rain doesnt get all over the alternator and electrical components.
vasily, what did you do to make sure rain doesnt enter (and if it does, where does it go?)
Old Apr 17, 2006 | 01:11 PM
  #88
Trajiksmax's Avatar
Proud Maxima Owner
Still haven't seen any funtional scoops yet. Out of all the posts I like Caesars idea the best. Keeps the stocker look without cutting holes in the hood and is functional. It would be interesting if someone tested these in a wind tunnel to see what gets the maximum forced cold air.
Old Apr 17, 2006 | 03:03 PM
  #89
vsamoylov
all i did was use weather stripping on the bottom of the scoop and rtv. now it seals so good that the water doesnt get under the scoop and into the engine bay. the way i tested it was i used a water hose and ran the water on top of the scoop.
Old Apr 17, 2006 | 04:46 PM
  #90
jvelos3's Avatar
Originally Posted by kormax97
WOW
Even going 10mph (off the line) will have air going through that hole. You must be on crack if you think there will be some kind of invisible shield of pressure that won't let any air in through that hole, Mr. Chemistry.
You keep saying it's better to get air through the fog light. How do you get the intake filter to be behind the fog lights? You mean the injen kind which sits right behind the radiator?
the place racing intake requires a 3" hole beside the battery to be drilled in order for a pipe to be routed outside the engine bay and into the compartment behind the foglight. You can get a knock off of the pr intake on ebay for like only 30 bucks.
the fact is that the hole is very tiny. If you think that the forced air will go into such a tiny hole and effectively reach the filter...you are wrong.
Jimes setup is nice since it separates teh intake from the rest of the engine bay. By having the pipe end exactly where the headlight opening is...it forces the air to have a DIRECT path into the intake.
an INdirect path will be close to useless.
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
