300ZX Brakes
300ZX Brakes
So what all does one need to put these onto an I30, should be the same as a maxima, but what do i need, and how much is it
i know i need
Calipers (junkyard etc)
Pads, store, online
Bracket, how much, who/where
Lines?
fluid
rotors-online, store
What else and what all does this cost?
i know i need
Pads, store, online
Lines?
fluid
30mm Z calipers-anywhere
Z pads-anywhere
Cobra Rotors-anywhere
brake lines-brianV
relocation brackets-jeff92se
hub rings- jeff92se
fluid-anywhere
extra nuts and bolts to mount brackets- dealer or hardware store(make shure they are the correct grade)
someone to help bleed (pizza and beer)
Z pads-anywhere
brake lines-brianV
hub rings- jeff92se
fluid-anywhere
Originally Posted by VIP Maxima
calipers from www.rockauto.com
Originally Posted by Akumachan
Got mine off eBay for $328 shipped, so thats a fair price.
Any ideas?
Originally Posted by kcryan
will these fit with my stock 15 inch wheels that i still use in the winter??
Stock wheels will not clear the 300z calipers, if you do the true BBK, you will need wheels larger then 16's to clear them.
skyline->300zx->maxima
Hey guys I have a related question for you. I might just post this as its own topic, but I'll start here. I have both a Maxima (97) and a 300ZX (91.) Could I take the brakes from the 300ZX and put them on the maxima and buy a skyline upgrade kit for the 300ZX? that way I could easily upgrade both cars. what stuff would I need?
Yes you could, from what Ive read the Skyline brakes are basicly the same as the 300z brakes, 4 piston calipers.
If your 300z is a 91 it should have the 30mm calipers.
To swap them over to the max, you have two choices.
Z32 swap which uses the Z32 rotors( need to be milled down) Z32 calipers ( either 28mm or 30mm) and conversion lines
or the BBK kit which uses the Z32 calipers (30mm), larger rotors either 04 Maxima or Cobra rotors ( require hubcentric rings) and the relocation brackets plus conversion lines.
here is a site that expalins the differences in Z32 calipers
http://importnut.net/300zxbrakeswap.htm
You can use Q45 calipers instead of the Z calipers. They aren't 4 piston but they are 2 pistion and it is a pretty beefy caliper. I am planning on using the Q45 caliper, 2k4 maxima rotors and Matt blem's relocation brackets.
You can use the 16's if you do the simple 300z swap, not the BBK setup.
oh that was one of the things i was worried about too. the maxima is my everyday driver so im not too concerned about making it a speed machine, thats what the 300zx is for. i was just wanting a performance upgrade without too much cost. you think thats a good idea? quick swap or lots of otehr parts involved? (the skyline to 300zx to maxima swap)
Im not too sure about the Skyline to 300z swap. I would imagine they would just swap over.
For the 300z to maxima you will need,
300z rotors (milled down 4mm)
conversion brake lines
calipers (from your 300z)
and wheels to clear the calipers. The 300z wheels will clear them.
If not, you need 16inch or larger wheels, plus the spoke design of the wheel plays a part of it also.
Look in the wheel/ tire section. There is a list of some wheels that clear the calipers.
I had to use a 5mm spacer for my 18 inch wheels to clear safely. They cleared without them, but just barely. i used the spacer just to be safe.
Im putting 300zx brakes on my 2005 Maxima. I scored 30mm aluminum calipers on ebay for $80 shipped, and Matt Blehm is sending me the relocation brackets and Stainless Steel lines for another $210. I plan on using Hawk Pads. I am painting the calipers red with bronze letters to mach my bronze rims. Im curious as to whether the braking will be better since Im using stock rotors.
are you saying take the wheels off my z and put them on the max? i dont want to do that, would i need different wheels for the max?
Stock 4th gen Maxima wheels are not going to clear the calipers, sorry.
If you want to do the swap, you will need to get different wheels to clear the calipers, the offset and spoke design will determine if they will clear.
here is more info on what wills will clear and what to look for...
http://forums.maxima.org/showthread.php?t=417562
will Q45 ones fit with my 15's? and what does this bracket cost?
Originally Posted by zack342
You can do q45 calipers and 300zx rotors if you mill 3mm off the diameter. taht will fit under your 15's
Originally Posted by mrchris951
ok what part of the rotor has to be cut down? If was looking at it from the side its too wide from front to back?
The radius has to be milled down...and when ll sid and done they are about the same size and maxima rotors so all ur gettting is 4 piston calipers...may as well goto mattblehm.com and get teh whole kit that uses 12.6" rotors or Jeff92se has brackets for 13" cobra rotors
Once milled down, they are smaller then the maxima rotors, but MUCH thicker.
The control arms have to be grinded down a bit due to them being thicker, if not the rotors will rub the edge of the control arm when turning leaving a groove in the rotor.
alum vs iron
Z pads-anywhere
brake lines-brianV
hub rings- jeff92se
fluid-anywhere
Z pads-anywhere
brake lines-brianV
hub rings- jeff92se
fluid-anywhere
04-16-2020 05:15 AM
HerpDerp1919
09-29-2015 02:02 PM
