A little help here
Old Jun 14, 2001 | 11:59 PM
1/3There2/3ToGo's Avatar
I am new to the whole modifying scene and need some help. If I buy a Y-pipe do I need to get a new muffler? Where can I find a ECU chip? Where can I find lowering springs for about a 2" drop? Will 19" wheels fit? Where can I find a lightened flywheel? Where can I find a lightened under drive pulley? Any answers to these questions will be VERY appreciated.
Old Jun 15, 2001 | 02:16 AM
BrianV's Avatar
Muffler isn't required if u get ypipe.
Sprints drop the car 2"
19's will fit
ECU Chip is onyl cool on 95 and 96 and GeForce Makes it. Flywheel helps, Stillen and Unorthodox have a piece.
Old Jun 16, 2001 | 12:46 AM
Thanks!
I guess I should have described my car - its a 1995 GXE auto. I am also looking for a lightened underdrive pulley. If anyone knows where I can get one please let me know.
Old Jun 16, 2001 | 01:43 AM
justmax's Avatar
hi
unorthodox also has a udp, and I may be wrong, but I don't think you can do an aftermarket flywheel on an auto (cuz auto doesn't use a flywheel!)
am I wrong guys?
justin
Old Jun 17, 2001 | 11:36 PM
Re: hi
am I wrong guys?
justin
Thanks for the unorthodox input, I too may be wrong but how is it possible for an auto not to have a flywheel?
K
Old Jun 18, 2001 | 06:36 AM
jiaxima96's Avatar
Long time ago when I had my 86 Sentra serviced, the shop told me that in an auto the similar thing to the flywheel is called flexplate (not sure if only Nissan calls it that way). If I still remember right, it is the plate with teeth around its perimeter to let starter grab it. I had it replaced with a genuine Nissan part about $80 that time because about one third of it were worn badly.
That's all I can recall now. Sorry if I'm completely wrong, or the info doesn't help.
Old Jun 18, 2001 | 08:01 AM
Screaminfast's Avatar
Hope this helps....
No. It only replaces the Y-pipe. You dont need anything else.
G-Force makes an ECU. Its for the 95/96 maximas. You can use it in a 97, but you have to use a 96 ECU, and change the O2 sensors to 96 O2 sensors. Talk to Cheston (Chebosto). He usually takes care of the G-Force Group Deals.
Eibach, Sprint, H&R are the big names who make springs for the Maxima. Anyone who carries these, including Stillen, will have them.
Yes.
Stillen makes a flywheel. I've heard its a good piece. I think some other companies make the Flywheel, but I dont remember who.
Unorthodox Racing makes one. You can get it from Stillen or anyone who carries it.
Old Jun 19, 2001 | 12:07 AM
Thank you screaminfast
Thanks for all the info! I have a hunch that auto max's have a torque converter instead of a flywheel. This is what a friend told me(but his knowledge of cars is even smaller than my limited amount). If this is true is there a mod out there that will help quicken up my rpm cycle?
K
Old Jun 19, 2001 | 06:15 AM
Re: Thank you screaminfast
K
Yes, get a higher stall torque converter, and a Valve Body upgrade. You'll be very happy with those.
Old Jun 19, 2001 | 06:37 AM
Sonic's Avatar
Don't forget about the transmission cooler too.
Old Jun 19, 2001 | 06:47 AM
Good Call.
Old Jun 19, 2001 | 08:57 PM
Who makes them & where can I find some?
First off, Thanks for the info. As I said above my car knowledge isnt vast - especially when it comes to after market mods and engines, I'm totally lost. Do either of you, or anyone else, know where I might be able to purchase a higher stall touque converter, a valve body upgrade and a transmission cooler? Any rough cost estimates for these parts?
K
