Sagging rear 97 GXE maxima????
Old Apr 19, 2006 | 09:58 AM
x8ver
Ive got a sagging rear 97 GXE maxima???? I have installed new tokico shocks and springs. I thought that would have taken care of problem but did not. What could be the reason. It looks like I need to change something but all I see is the beam what do I need to fix a bushing or ???? I have noticed this very rarely on the the 4th gen maximas only on really beaten up ones.
thanks jl
Old Apr 19, 2006 | 10:18 AM
tavarish's Avatar
fwd gone rwd cr00
do you have a system in the trunk?
The springs also have to settle.
Old Apr 19, 2006 | 10:24 AM
x8ver
Yeah there is but before system it looks wrong. When people get inside it looks really bad. It doesnt hit tire but looks hovering very close. I am going to keep reading or might put back stock springs in rear to give an extra inch back. To level off but dont feel that is the proper fix.
Old Apr 19, 2006 | 12:13 PM
DennisMik's Avatar
is the front end normal height or has it been raised up? if the front end is up, the rear will be forced down. otherwise, you have the wrong springs in the rear or excessive weight in the rear.
Old Apr 19, 2006 | 02:15 PM
x8ver
No the front end is good. I know what you mean but the back is off. I wanted to know other than shocks and springs is there anything else that could make the rear sag. If it hit something or objects struck the undercarriage could something underneath need repair. I was reading in the sticky and showed the rear as a multi link beam. Is there something there that can affect rear sagging???
Old Apr 19, 2006 | 03:44 PM
Black Maxima
Take pictures of the rear of the car...
Old Apr 19, 2006 | 04:25 PM
x8ver
good idea....
Old Apr 19, 2006 | 05:12 PM
f550maranello2's Avatar
werd i have a similar problem
Old Apr 19, 2006 | 05:28 PM
RA030726's Avatar
I'm nutty for Nissans
The wheel wells are smaller in the rear so the gap looks smaller. You can get spring coil boosters or poly spacers to help. Or you could install a different set of rear springs.
Old Apr 19, 2006 | 08:04 PM
x8ver
I definitely need these where can I get these any links or recmd... thanks
"You can get spring coil boosters or poly spacers to help"
Old Apr 20, 2006 | 12:24 PM
RA030726's Avatar
many auto parts stores have the coil boosters that are metal and spread the coils apart. Im not sure where to get the spacers, but progress and es make them.
http://forums.maxima.org/showthread.php?t=442802
Old Apr 22, 2006 | 11:23 AM
x8ver
Im going with the spacers thanks for all the info and link.
thks jl
Old Apr 22, 2006 | 11:43 AM
WhiteMax96's Avatar
maybe it's the bushings of the multi link beam that are too worn. I'm planning to replace mines soon.
Old Apr 22, 2006 | 11:57 AM
RA030726's Avatar
^^^^ right.................. there are no bushings on the beam that will affect ride height.
Old Apr 22, 2006 | 12:14 PM
njmaxseltd's Avatar
Old Apr 23, 2006 | 01:30 PM
x8ver
OK so which is it are there bushings or not....because that is my original question??? Im going to take pics and look for those bushings....
Old Apr 23, 2006 | 01:31 PM
x8ver
so is there bushings or not???????
Huttig2009
Sep 25, 2015 03:31 PM
Ray229Harris
Sep 16, 2015 08:16 PM
Maxilano
Aug 31, 2015 07:33 PM
wingsfan24
Aug 15, 2015 07:35 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
