help: rpm does not go past 2k...
Old Apr 19, 2006 | 01:16 PM
dipitydoo's Avatar
Hi, was just driving my maxima today, and the rpm limits at 2k, similar to a rev limiter at the redline. This happens regardless of what gear its it; neutral, park, etcl., as soon as the rpm meter gets to 2k, it cuts back. I replaced my old cone air filter with another brand about a week ago. I removed the filter and it does the same thing. Any suggestions?
95 Maxima SE
Auto
210k miles
Old Apr 19, 2006 | 01:25 PM
Mxrider52's Avatar
I support for what?
Your MAF isnt plugged in or isnt plugged in all the way. It the black square thing behind the filter.
Old Apr 19, 2006 | 02:07 PM
dipitydoo's Avatar
its plugged in all the way. Could it have gone bad during changing of the air filter?
Old Apr 19, 2006 | 02:12 PM
97_Max's Avatar
does anybody have a picture of this MAF part so I could So..
Old Apr 19, 2006 | 02:53 PM
BlackMaxdout's Avatar
the MAF could have gotten really dirty somehow when you changed the filter. You can sometimes rinse them out with alcohol. Sometimes Nissan ECU's will throw the car into "safe mode" and cut the RPM's way back...but usually you get a CEL with it.
Old Apr 19, 2006 | 05:19 PM
dipitydoo's Avatar
no CEL lights, the rpm just stutters right at 2k, won't go any higher. Just for sh*ts, I may try to reset the ecu. Anyone have the steps to do that, I don't remember, it was a while ago the last time i did that. I apparently don't have permission to use the search function. anyone know why?
Old Apr 19, 2006 | 07:06 PM
b00b's Avatar
The same thing happened to my friend's 95. Bring it to autozone and ask them for the OBDII reader and tell them to reset the ECU and problem solved.
Old Apr 19, 2006 | 07:25 PM
maxgtr2000's Avatar
KH3 by popular demand
Mine did that with a faulty apexi vafc hooked up to it. Got the CEL though. Strangely the symptoms went away when maf was installed normal, but cel stayed for a couple weeks then went away on its own.
Old Apr 19, 2006 | 07:52 PM
NYC32798's Avatar
My friend also had the same problem with his car after installing an intake. His CEL was reading the MAF. I told him to a screw driver to reset the codes and since then his car runs fine. No MAF code.
Old Apr 19, 2006 | 09:41 PM
dipitydoo's Avatar
no cel on...yet. Anyone remember the procedures for resetting the ecu? I hate to drive this to autozone in this condition.
Old Apr 19, 2006 | 09:47 PM
99grnmaxgxe's Avatar
It's in the Stickies.
Old Apr 20, 2006 | 02:07 PM
dipitydoo's Avatar
thanx, I'll check it.
Old Apr 22, 2006 | 01:56 PM
0260N9's Avatar
I unplugged my MAF sensor today and drove it by accident today. I had the exact problem that you described. The car shuddered and the rpms would not go past 2-3k. The only difference was that mine thru a cel code when i had it checked at autozone. Hope that helps.
Old Apr 22, 2006 | 07:00 PM
dipitydoo's Avatar
I reset the ecu, the problem is gone. I haven't had a chance to test drive it yet, but it seems ok. Thanx everyone for your help.
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
