e-brake light always on.
Old Apr 19, 2006 | 09:42 PM
mdma's Avatar
e-brake dash light is always on, even when the e-brake is disengaged. what is the fix?
Old Apr 19, 2006 | 10:00 PM
zazon's Avatar
fill your brake fluid up
Old Apr 19, 2006 | 10:04 PM
tavarish's Avatar
fwd gone rwd cr00
check the brake fluid.
Old Apr 20, 2006 | 07:54 AM
sodie14's Avatar
haha...everyone always says the break fluid....i would be willing to bet that the problem is in the sensor for the e-brake.
take apart your center counsel....lift up the trim piece around the shifter, remove the 2 screws and then remove the 2 screws on each side by the seats....unplug your heated seats if you have them and then the whole center counsel lifts right up. inside you should see 1 wire going up to the base of the e-brake. it has a spring loaded mechanism that, when the e-brake is engaged, expands and contacts another piece of metal and closes a grounded loop circuit which will turn the light on in your dash. the plastic brackett where the wire can be connected/disconnected brakes off pretty easily and thats prolly where your problem is. you can fix it with some create thinking....replace the parts....or simply disconnect it and make sure that the circuit cant be looped and then the e-brake light wont ever come on again.
any questions, feel free to ask
Old Apr 20, 2006 | 08:03 AM
Kevlo911's Avatar
Kevlo for President
Break Fluid huh. New one to me, care to explain
Old Apr 20, 2006 | 08:57 AM
aznprid972's Avatar
Could be an early indication that your brake pads are low as well. Don't just keep topping off your brake fluid when it's really your pads being worn down.
Old Apr 20, 2006 | 09:07 AM
DcMaN's Avatar
if it were the ebrake sensor the light wouldnt come on at all. Most likely it is your brake fluid
Old Apr 21, 2006 | 01:20 PM
sodie14's Avatar
depends on how the sensor is broke...i had this happen on my car and the light was always on. the spring had gotten nocked out so due to gravity, it would always "fall foreward" and think that the e'brake is pulled....if anything else, its an easy thing to take 5 mins and rule out that as a possibility
Old Apr 21, 2006 | 01:58 PM
zazon's Avatar
OR take 10 seconds and visually examine your fluid level, and 20 more seconds to top it off
Old Apr 21, 2006 | 09:41 PM
whitegold's Avatar
I never seem to disangage my ebrake all the way.. maybe your like me and driving with a partially engaged ebrake?
Old Apr 23, 2006 | 12:28 AM
mdma's Avatar
ebrake is fully disengaged
I will check brake fluid, but the light now goes off after I disengage the ebrake. Other times, it will stay on. Seems random, but I doubt it.
Old Apr 23, 2006 | 12:30 AM
mdma's Avatar
is this a 'safe' fix? is my brake light supposed to notify me if I need brake fluid?
Old Apr 23, 2006 | 12:42 AM
Mr. Blue Sky's Avatar
if the newer gens are like my 2nd gen, then yes it does warn you of low brake fluid levels.
Old Apr 23, 2006 | 01:04 AM
Turbo1er's Avatar
Doin' it 4 da shorteez
This is intriguing to me.
Old Apr 24, 2006 | 02:43 AM
mdma's Avatar
Light was on for 2 out of five rides today. Brake fluid is 'ok,' but I can top it off to the max level. Instead of buying some, I'll just get an early oil change which includes it. I'll see if this fixes it.
Old Apr 24, 2006 | 05:21 AM
lefty
Had the same problem. Had to top up brake fluid and light when out.
However, fluid was low due to low brake pads. Check them anyways.
Old Apr 24, 2006 | 05:28 AM
Blaxima95's Avatar
Owns way too many maximas
You shouldnt ever have to top off your brake fluid. ONLY if there is a leak. If there is no leak, and the resivor is low, your pads are most likely in need of replacement. If you top off the resivoir when the pads are the culprit, you are going to make a big mess when you open up the calipers for the new pads
mvm062
Nov 30, 2020 09:00 AM
Maxie40
Sep 14, 2015 11:28 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
