Transmission Shift Lag...PLEASE ADVISE
Old 04-20-2006 | 06:03 AM
VTRUGBY's Avatar
I have 130k miles on my 97 maxima. About 15k miles ago I started to get a shift lag between 2nd and 3rd gear at 2k RPM. I have checked all fluids, I had my drive belts replaced and still nothing has changed. Does any one have any points of advise, transmission valve body?, exhaust back pressure due to a leak?. Please help.
Regards,
Sean
Old 04-20-2006 | 07:46 AM
Penguin1996's Avatar
when was the last time you changed the fluid and filter? if its been a while change it. when tranny fluid gets old and funky itll lag betweeen shifting especially if the tranny filter is clogged. try that itll cost you like $20 or $25. also check your ground points. i keep reading on this board how important it is to get ground to auto tranny's. if none of that helps...take it to a couple of tranny shops and see what they tell you, maybe they have a guy thats worked with max's and can tell you right away
good luck and god bless
Old 04-20-2006 | 08:08 AM
VTRUGBY's Avatar
I had the fluids changed about 30k miles ago. The fluid is still pink and the levels are fine. To be honest everything was fine I started to put the car in neutral during stops to conserve gas. Could the CPU need a refresh since the driving style changed?
HUMM.http://forums.maxima.org/images/smilies/scratchhead.gif
Old 04-20-2006 | 10:16 PM
i dont know man, im sorry. my mom used to have a windstar and when the sensors and valves started going it used to shift hard as hell. i know thats not your problem but i dont know what else to think of?!
good luck
Unclejunebug
04-02-2016 05:42 AM
hayne
10-05-2015 11:53 AM
Noela
09-26-2015 08:22 AM
Quick Reply: Transmission Shift Lag...PLEASE ADVISE
