Ignition Switch going bad?
Old Apr 20, 2006 | 11:52 AM
__Kevin__'s Avatar
When starting the car I have to turn the key anywhere from 3-6 times to get it to fire. All the electronics come on, but it won't start right aways. Could it be my ignition switch, Or something else?
Old Apr 20, 2006 | 04:56 PM
_ck69_'s Avatar
sounds like the ignition swtich. those symptoms happened to me and i swapped out mine awhile ago. can't really go wrong with replacing the switch, it's a relatively cheap part. good luck.
Old Apr 20, 2006 | 07:39 PM
__Kevin__'s Avatar
Cool, Thanks Man.
Old Apr 20, 2006 | 08:36 PM
CRiME's Avatar
oem ftw!
if you hold the key at a certain angle, shake it around, or hold it for a few seconds while trying to crank, does it have any effect on the starting? if so, it's most likely your ignition switch. are you getting a click from under the hood? next time you go to start your car listen very carefully for a click. if you're getting a click, it's more likely to be your starter. i was getting a click,and instead of changing the switch, I removed the starter, cleaned it up, re greased it as seen here: http://forums.maxima.org/showthread.php?t=461274
sanded the connections to the battery / ground. This solved my problem. Clean your battery terminals too, if they're dirty.
Old Apr 20, 2006 | 08:41 PM
Black Maxima
I changed my friends ignition switch in a Wendy's parking lot. Turned out it was his starter malfuctioning and not the ignition switch. He needed a new one anyway and it was easy to put in.
Old Apr 20, 2006 | 11:12 PM
__Kevin__'s Avatar
no clicks, battery terminals are fine. I haven't really tried moving the key around or anything. I just Turn the key a few times and eventually it starts.
Old Apr 21, 2006 | 09:10 AM
Maximus_95's Avatar
does anyone have a write up on how to switch the ignition?
i think i have a problem too, but a tad different.
sometimes my car turns on right away. and sometimes, when i turn the key, there is nothing, and i have to wait approx. 3 mins before i start it up again and it turns on, and sometimes i turn the key, hold it there for about 2-3 seconds and the car turns on.
Im' really confused, Does anyone happen to know if this is the ignition switch problem also?
Old Apr 21, 2006 | 11:19 AM
CRiME's Avatar
oem ftw!
yes, for both of you guys, that sounds like an ignition switch problem. it's an easy job, replacement instructions can be found in this thread
http://forums.maxima.org/showthread....gnition+switch
Old Apr 21, 2006 | 11:32 AM
__Kevin__'s Avatar
RIght on. I had an Idea that thats what it was, but I wanted to get some concurrance before I started tearing into it. Thanks guys.
Old Apr 21, 2006 | 12:09 PM
lee's Avatar
lee
i have the same problem, i just ordered mine from everythingnissan.com for $23.
Old Apr 21, 2006 | 02:49 PM
Maximus_95's Avatar
thanx, now i dont have to waste money to replace something i thought was wrong.
anyways....does anyone have pics of this ignition switch?
Old May 21, 2006 | 11:04 AM
crisp44's Avatar
i had a similar problem with my ignition but i ended up simply rubbing the wire to the starter and the car started right away. i guess it was dirty and it was blocking the connection
shilov
Feb 19, 2024 09:40 PM
mikeg75
Nov 30, 2015 05:12 PM
James92SE
Oct 8, 2015 04:57 PM
rnb754
Sep 14, 2015 11:39 PM
