Does a Faulty Tranny Affect the Idle?
Old Apr 23, 2006 | 08:34 PM
99grnmaxgxe's Avatar
I have been having high idle problems and noticed that my tranny now jerks really hard when shifting, sometimes hesitation occcurs. So I was wondering if the tranny is making my idle high or is it the high idle affecting the tranny?
Old Apr 24, 2006 | 08:53 AM
I also checked my tranny fluid and it seems to be at the right level and still good (red). Does the TPS have to do with this? I found it unplugged a while back and plugged it back in with no better results.
Old Apr 24, 2006 | 12:14 PM
Motorhead52's Avatar
You might have a vacuum leak or a stuck IACV valves. It's probably something related to the throttle body and by the sounds of it somebody has already mucked about trying to fix it.
Old Apr 24, 2006 | 01:39 PM
Well, could it be my TPS? I found it unplugged not too long ago, do you think it's ruined?
Old Apr 24, 2006 | 02:10 PM
clive's Avatar
100% chingon
Look, all the TPS is, is a wirewound potentiometer, same as old radios used to have. There isn't anything inside to 'ruin'. The TPS eventually goes bad because it always returns onto the same spot on the track when the throttle is closed, and the resistance wire gets worn through. You can run the motor without the TPS. It does affect idle.
Now, you should notice that the TPS has a small amount of adjustment available, it is a mounting slot rather than a mounting hole . . . take a look. Slacken the 2 screws just enough to move it in the slots and gently wiggle it forward and back. If the TPS is functional you will get a change in idle speed.
Before you do anything else clean the connectors to the MAF and TPS particularly.
But I don't think for a minute the TPS is the fault.
You have not given us any meaningful info. "High idle" - what do you mean by 'high'?
Clunking and banging in an auto tranny, esp. in overrun, is usually a bad TC.
Old Apr 24, 2006 | 03:03 PM
What should I use to clean the connectors? The idle is wierd, it is off and on. Sometimes it idles at 1000 and then it randomly drops to 600. I don't know what's wrong, I don't want to adjust the idle b/c when it is not idling high, I would have a idle that would be too low.
Old Apr 24, 2006 | 08:30 PM
clive's Avatar
100% chingon
Take the connector off, spray with carb cleaner, work the other part in and out for a while . . . in and out . . .
alternatively borrow a toothbrush from a
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
