Clicking noise when car is beggining to move
Old Apr 25, 2006 | 09:38 AM
ukraini9mofo's Avatar
Car clicks sometimes when i get it going from a stop, if the motion is no smooth enough, if say a shift from 1-2 or 2-3(rarely) is not perfect and the car dips a little it makes a "click" sometimes. I think its coming from under the car, I checked everything that could be loose in the engine bay, maybe its my exhaust moving around.
Any ideas?
Old Apr 25, 2006 | 09:41 AM
MorpheusZero's Avatar
Just a single click or repeated?
Old Apr 25, 2006 | 09:47 AM
Just one click like a plastic hir other peice of plastic
Old Apr 25, 2006 | 03:21 PM
clive's Avatar
100% chingon
Worn bushings in the steering somewhere?
Engine mount(s)?
Old Apr 25, 2006 | 06:21 PM
Rated Maxxx's Avatar
Sorry to be a little off topic as I can't make my own posts (dunno why) I have a 97 Max GXE and I just recently changed the throwout bearing and the clutch. I changed the throwout bearing because when I bought the car I heard this rubbing sound, like a skateboard riding sound that you would only hear if you didnt step on the clutch. Fast forward to now, new throwout bearing and a new clutch and the sound is still there. Do anyone know what else could be the problem.
Old Apr 25, 2006 | 07:00 PM
eman88's Avatar
I had a simular experience in my 97 max, took it to 3 shops before they found the problem, my passenger side axle was bad,,the bearing in the axle was vibrating, making the clicking noise...
Old Apr 25, 2006 | 07:09 PM
HallKemar
^how much did that cost to fix?
Old Apr 25, 2006 | 07:14 PM
eman88's Avatar
$90 for the part...$40 to install
Old Apr 26, 2006 | 09:20 AM
So you guys think its my axle?
Old Apr 26, 2006 | 02:02 PM
dgeesaman's Avatar
Maintenance Monster
Well I have a similar clunk in my right/front suspension area. I replaced the axles and it didn't change but I do have new axles now, and at 145k that's worth something
I also second looking at the engine mount(s).
As for the guy with the unrelated noisy transmission, it sounds like the tranny input shaft bearing is damaged. But it's hard to say really.
Dave
Old Apr 26, 2006 | 05:40 PM
eman88's Avatar
Well in my case it was faulty axle,,,but I changed the hub bearing,brakes,tie rod,and tires..in the process to solve the problem..
Old Apr 26, 2006 | 07:51 PM
dblair's Avatar
I had the same symptom. In my case the problem was in the front suspension/streering...it was the passenger side control arm if I remember correctly. Parts and labour was less than $100.
Hondarydr
Dec 30, 2024 06:15 PM
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
MikesChevelle
Aug 9, 2015 11:50 AM
