wierd sounds when i make a turn !! help
Old Apr 27, 2006 | 08:00 PM
jaep0913's Avatar
whenever i make a turn [left or right] it makes this wierd multiple*clicking* sounds. I havent been able to get a check up on it, but i wanna know whats wrong with it first. anyone know ?
Old Apr 27, 2006 | 08:03 PM
kormax97
your boot is probably torn and need replacement. if it's to the point where it's making noises, I suggest replacing the complete axle.
to check which side is leaking grease from the torn boot, just look behind the rims and you will notice a good amount of grease all over it.
Old Apr 28, 2006 | 04:25 AM
dgeesaman's Avatar
Maintenance Monster
Only change the axle if it's leaking grease. Bad axles will click whenever the car is rolling and the wheels are turned. The clicks may change in frequency with the speed the car is moving.
The other common issue is a strut tower bearing that clicks whenever you rotate the steering. A bad bearing will click mostly when you are turning the wheels and the clicking will depend on how quick you are turning the wheels.
Dave
Dave
Old Apr 28, 2006 | 04:58 AM
ALSOUSA99MAXIMA's Avatar
This seems to be a common problem with these cars, I have seen a couple threads on the clicking noise, mine clicks 2 but only when i turn it all the way and thats when I am at a stop.
Old Apr 28, 2006 | 05:18 AM
AresFury's Avatar
My car never makes that sound but it does make an odd squealing noise every now and then when I start it up.
Old Apr 28, 2006 | 07:37 AM
hobokenkid's Avatar
I went to the dealer with same complaint , they found nothing wrong they told me the brakes need replaceing? they actulayy do and are rusted but I see mo reason for that to make the noise
tsi6001
Oct 3, 2022 10:23 PM
alixc
Aug 11, 2020 01:48 PM
Lakersallday24
Jun 16, 2019 01:35 AM
sake1bs
Sep 19, 2015 09:32 PM
follyburr
Aug 7, 2015 09:50 PM
