CF hood
Old Apr 28, 2006 | 07:30 AM
my97maxi's Avatar
CF hood
does any body else that has a cf hood has problems closing it, or is it just mine?
Old Apr 28, 2006 | 10:57 AM
darklegend06's Avatar
What do you mean closing it? The latch doesn't match or what? You have to adjust the bolt area to make it fit. I also think you should take off your hood struts cause it was made to lift stock hood weight not some light CF hood. Also where did you purchase your CF hood and how much. Thanks
Old Apr 28, 2006 | 11:57 AM
95turbo gxe's Avatar
anyone know the weight differance in the stock hood and the carbon fiber hood
Old Apr 28, 2006 | 02:59 PM
MDeezy's Avatar
Depends on who made his hood. I am using the hood struts and its fine with my hood, not too strong, its just right.
Mine closes just fine, it wont latch so I unbolted it and left it out of the way and just use hood pins.
I believe the stock hood is around 25lbs, averg CF hood is ~17lbs
Old Apr 28, 2006 | 03:02 PM
my97maxi's Avatar
i not sure whats wrong with it, at times it takes about 5 min before i can actually close it, the hook on the hood and the latch on the car seem like they dont want to go together and click shut, sumtimes it will close right away and sumtimes its an hassle. and i got it at carbonefx; cf hood + cf eyelids for 450 shipped.
Old Apr 28, 2006 | 03:06 PM
my97maxi's Avatar
Mdeezy.. how are the hood pins? any problems with it? and you dont use the latch on the car at all??
Old Apr 28, 2006 | 03:09 PM
MDeezy's Avatar
Hood pins are good, there on there tight as its the only thing holding the hood down. I would use the latch but the latch on the hood just doesnt seems to be strong enough to push into the latch on the car. So I just use pins and it hold well, many long distance car rides with no worry.
Pop your hood and loosen the bolts on your latch and try to move it up more or which ever direction would give it proper clearance or no resistance.
Old Apr 28, 2006 | 03:29 PM
my97maxi's Avatar
MDezzy a couple more questions: where did you get your hood pins from? how much they cost? and did you get a 5 inch or 6 inch pin??
thnx
Old Apr 28, 2006 | 03:39 PM
MDeezy's Avatar
my hood pins were some generic ones I got off ebay. They hold up very well.
not sure what you mean by 5" or 6" pins. My hood pins are this style.
Old Apr 28, 2006 | 05:46 PM
DrTySOUFMaX23's Avatar
yea i have problems shuttin my cf hood sometimes but all you gotta do is put both hands down on the hood near the latch and push it down quick and hard but not too hard and it should work it might take you a few times but you'll get it..
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
