axle bad again after a week???!??
Old Apr 29, 2006 | 08:45 AM
ImmaSquashYou's Avatar
so i changed my axle like about a week ago, maybe not even. It was making a lil clunking noise for over year, and i decided its time before the wheels falls off as i'm making a turn. So i go to napa n buy a rebuilt one. But now the thing is, i'm getting a evern BIGGER clunking noise as i turn to the left coming from the right side. This passenger side i just replaced. I'm sure i did everything correctly, but has anyone heard of anything like this?? i mean i hear people having it make noises after like a week?? is this possible or is it something else????
Old Apr 29, 2006 | 09:46 PM
specsgirl's Avatar
it's possible that the one that you got was a bad one. I believe that NAPA uses remaned parts. I had this happen twice to me on the same side on my civic.
Old Apr 29, 2006 | 10:59 PM
ManualMaxima's Avatar
5th Gen till she dies!
how far are you dropped, they go out pretty fast is your slammed like your sig picture looks. i wore out a raxle in 2 weeks
Old Apr 29, 2006 | 11:01 PM
ThisMaxIsTight's Avatar
2 weeks ? .. for real ... thats crazy ... how could that be
Old Apr 30, 2006 | 02:38 AM
WielkiWaac's Avatar
MaximaDriver
damn. thats what happend to me today.
i replaced my passenger and driver side axles during 5 spd (14 jan). two or three weeks ago axle started clicking and today making noise like crazy. thanks god its on warranty
Old Apr 30, 2006 | 02:14 PM
Apparition's Avatar
Ichiban King
.. are you missing a wind deflector? lmao
Old Apr 30, 2006 | 05:59 PM
yea, i'm gonna take it out n go back n be like i just instaleld it n it went. I dunno what to tell ya. He asked me if i wanted a reman or a reg., i just took the reman. I'll use the reman one again and see if it's any good, otherwise i'm just gonna tell them straight out, yo gimme me money back punks!
Old Apr 30, 2006 | 07:02 PM
chillin014's Avatar
waht do yall mean by "wear out"
i thought clicking only happend when the boots actually ripped.
i just replaced my driver side today, it sure as helll better last a long time.
raxle.
Old Apr 30, 2006 | 07:32 PM
well chillin,
since u got urs from raxles, u most likely won't have a problem. What happens to these reman ones are like *******s like me who replace it after they've been ripped for like more than a year. Then we give it back to the man. and they just bascially put a new boot on, grease it up, and assume that its fine. I'm not sure what they do to test it, but prob not much and throw it on the shelf. Thats why mine was prob bad to begin with.
Old Apr 30, 2006 | 11:12 PM
maximaseefu's Avatar
if it is a clunking noise listen to see if any grinding noise also cause it could be your wheel bearing.
Old May 1, 2006 | 12:05 AM
1996blackmax's Avatar
If you also heard some humming sounds, that could also point to a bad bearing. I finally changed mine when it was clunking pretty bad.
Old May 1, 2006 | 04:31 AM
MaximaSE96's Avatar
Maxima Owner
ur too low
Old May 1, 2006 | 05:26 AM
Like humming when i'm turning while its clunking??? I never heard a bad wheel bearing before, so i don't know what it sounds like...if you guys could be more specific, it'll be great...n i'm guessing theres no way of telling if its worn??
Old May 1, 2006 | 05:32 AM
it sounds like metal on metal either grinding or rubbing.
Old May 1, 2006 | 06:30 AM
MDeezy's Avatar
clunking isnt usually a axle problem. Wheel bearing or Ball joint could be the culprit.
Old May 1, 2006 | 07:29 AM
Digitized's Avatar
would a bad axle or drive shaft be the cause of clunking noise only occur when I am making left turns ( noise coming from passanger front wheel)..??
Old May 1, 2006 | 08:02 AM
The humming I had was while I was driving. Kind of like having worn out tires. You would not have heard this just while turning slowly (at least I did not). When the bearing was really bad, it was just clunking and grinding, then I changed it. I believe that the wheel will have a certain amount of play if your bearing is going bad. Nothing major, but noticeable. Someone correct me if I am wrong...
Old May 1, 2006 | 08:35 AM
MDeezy's Avatar
very possible.
Old May 1, 2006 | 08:48 AM
Digitized's Avatar
Thanks, last thing I want is my wheel falling off while driving back to Montreal...
Old May 1, 2006 | 08:57 AM
MDeezy's Avatar
that is not fun . . . trust me I've gone thru it.
What part in montreal?
Old May 1, 2006 | 09:18 AM
Digitized's Avatar
East end, Anjou ( next to St-Leonard)..
but currently in Markham, Ontario ( Toronto)
Old May 1, 2006 | 09:29 AM
ALSOUSA99MAXIMA's Avatar
Originally Posted by Emasculation
so i changed my axle like about a week ago, maybe not even. It was making a Lil clunking noise for over year, and i decided its time before the wheels falls off as I'm making a turn. So i go to Nap n buy a rebuilt one. But now the thing is, I'm getting a Even BIGGER clunking noise as i turn to the left coming from the right side. This passenger side i just replaced. I'm sure i did everything correctly, but has anyone heard of anything like this?? i mean i hear people having it make noises after like a week?? is this possible or is it something else????
if your as low as it looks in your Sig, the axle could be getting FY(Jed up because there is not enough clearance for the axle, so when you go over a bump, pot hole etc. you can be hitting it up against something
Old May 1, 2006 | 11:40 AM
i don't think that i'm that low because i still have like a 2 finger wheel gap on all wheels. Its been getting worse i think. I can hear it while just accelerating without turning. Is that the wheel bearing on the ball joint?? So should i go to napa n ask for another axle first?? or just change the wheel bearing, and if that doesn't work, ask for another axle, and then finally change the ball joint...????? Correct me if i'm wrong, but the balljoint is more expensive than the wheel bearings right? How much is the bearings n balljoint cost neways?
Old May 1, 2006 | 11:48 AM
i would say go to napa buy an axle, hub assm or brg, and ball joints, go home jack the car up shake the rim if it moves, that means ball joint, if not take the wheel off, take the axle off, if the axle is ok then replace the hub, then return the un used parts.
but i definitely thinking wheel brg, just buy a hub and save yourself the headache of pressin the brg off
Old May 1, 2006 | 01:26 PM
well i wore my raxle out real quick.....it is because i am to low. when iget some time i am rasing the car up and just dealing with the height, i am tired of wearing these axles out.
my axle is clicking real bad. and my boots look great.
Old May 1, 2006 | 02:09 PM
shavedmax's Avatar
jack the car up,make sure its off the ground, and take the right wheel and shake it at 3 and 9 and 12 and 6 if you have play at 3 and 9 it's a tie rod that's bad. if you have play at 12 and 6 it's a ball joint. if it hums like you're going over cut blacktop(like before they repave) its a wheel bearing. the sign that an axle is bax is clicking on turns. the boot doesnt have to be torn to do it. if all else fails, you have a bad strut or spring bushing.
oh, ald dont forget to look at your lower control arm busings. they may be worn and causing a clunking noise too
and to all the ridiculous suggestions i saw before. the height of the car has nothing to do with the axle hitting something. YES there is more stress on the joints when you're lowered, but it WONT cause a new axle to go that quick. i had my 3rd gen with hydraulics for 2 yrs with no suspension wear at all. and i would go from scraping my stillen side skits to being a foot off the ground.
Old May 1, 2006 | 07:35 PM
Thanks shaved max, i'll do that after finals. Update tho, It seems as if it only makes the noice when i'm accelerating. I cornered pretty hard without the gas and just cruise into the turn n out, no sound, as soon as i tapped the gas with the wheel a lil bit to the left, clunk clunk clunk clunk on the right wheel. Is that a bad wheel bearing???? Kinda funny, but why would it make a worse sound now that i replaced soemthing?? or was it just a coinincidence that something else went RIGHt after i replaced the axle?
Old May 1, 2006 | 08:29 PM
nitromax's Avatar
if all of the advice here doesn't help, let a shop check your front end. that way you can pinpoint the real problem then do the repair yourself.
Old May 2, 2006 | 07:49 AM
anyone still know why i can only hear the clunking while acclerating??
Old May 2, 2006 | 12:21 PM
shavedmax's Avatar
did you try anything i said? because if not, that's probably the reasson why it's clunking. you probably replaced the axle thinking it was bad when it was something else. dont get me wrong, recon axles can be bad, but i've never heard an axle clunk. only click on turns
Old May 2, 2006 | 12:50 PM
Stillen Maxima's Avatar
Pay to Play
It's ur axle bro...I replaced my axle like 2 weeks ago and now its clicking again!! But It only happends with the axles that are rebuilt. If you get a new one it would last for a WHILE..Oh and by the way my max is slammed as low as yours!
Old May 2, 2006 | 01:54 PM
shavedmax's Avatar
i give up. he said it's clunking while accelerating, not clicking. therefore it's not the axle.
Old May 2, 2006 | 04:26 PM
Gismo-T's Avatar
B!tch We Got a Problem
When strut bearings wear out, they also make noise when turning the wheel!
matts95max
Apr 23, 2025 10:44 AM
PH98I30
29
Feb 10, 2025 12:03 PM
boomerbrian
Oct 31, 2018 10:25 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
boomerbrian
Sep 4, 2015 08:25 AM
