knock sensor - where to buy?
Old Apr 30, 2006 | 03:52 PM
jaxima's Avatar
can anyone tell me where the best place is to get a knock sensor? Thanks
Old Apr 30, 2006 | 03:57 PM
Gismo-T's Avatar
B!tch We Got a Problem
got one from e-bay for $72.00 shipped!
Old Apr 30, 2006 | 04:32 PM
Pieps's Avatar
E-bay is fine. It is cheap and works well
Old Apr 30, 2006 | 04:34 PM
ManualMaxima's Avatar
5th Gen till she dies!
get one form ebay or a online dealer.......do nto go to an autostore
kmax's Avatar
Thanks for the tip, I just bought one too. $72 shipped.
Old May 2, 2006 | 08:39 AM
desteele's Avatar
This one was $85 shipped, and just got installed last night.
Words to the wise:
  • Use the 3/8" extension with the 3/8" U-joint - I shattered a 1/4" U-joint
  • Once you get the bolt loosened, get someone with small hands to get it all out. My hand looks like hamburger meat, but being 6'3" might have something to do with that.
  • Be careful when you are replacing the sensor - the plug has a little copper-looking "staple" (for lack of a better term) that you have to pull off first. I chipped my plug without realizing what was going on.
  • Lord this thing moves now...I wouldn't have figured on that much of a boost in pull.
Old May 2, 2006 | 08:45 AM
VIP Maxima
i will need one of these
Old May 2, 2006 | 09:05 AM
sky jumper
[*]Lord this thing moves now...I wouldn't have figured on that much of a boost in pull.[/LIST]
did you have any codes to tell you KS was bad?
Old May 2, 2006 | 09:31 AM
desteele's Avatar
Yeah, I was just procrastinating. Just ordered the rear O2 sensor which was the original code source.
Old May 2, 2006 | 11:56 AM
Ceasars Chariot's Avatar
Old Maxima Legend
South Point Nissan
888-254-6060 - Dave Burnette
Old May 2, 2006 | 11:57 AM
19maxima97's Avatar
try a junk yard for cheap alternative
Old May 2, 2006 | 12:07 PM
HallKemar
never GO AN AUTO STORE UNLESS, you are impatient.
Old May 2, 2006 | 12:43 PM
DanMaxima's Avatar
Or want to work the loaner system.
The cheapest I've seen a knock sensor online (though not looking too hard) was ~$125 (nissanpartstore.com), so yah, hit ebay first.
FYI for anyone who may be interested, there's a way to test your knock sensor before replacing it.
http://nicoclub.com/articles.php?id=157926
Old May 2, 2006 | 02:28 PM
jaxima's Avatar
thanks for all the help - I ended up getting one off ebay for $77 and change shipped 2nd day. Ebay is definitely the best place to find one when yours is bad.
Yes, I did have a code flash up, 3 actually. One was for the knock sensor (0304) and the others were 0302 and 0111. I tested the KS about a year ago and knew it was bad, just too lazy to replace it. I can't wait to see what the old maxima is gonna feel like with the new one. Time to fill the bottle!!!
Thanks again for the help, I would've ended up paying about 140 for that POS before I checked here.
Old May 2, 2006 | 04:42 PM
DanMaxima's Avatar
Glad it worked out well for you.
How many miles do you have on your Maxima? Just curious.
Old May 2, 2006 | 05:41 PM
jaxima's Avatar
136 k and running strong
Old May 3, 2006 | 06:12 PM
Hotsuma's Avatar
I bought mine from the dealer for 212 cause you have to inspect your car in jersery and my dad wanted to change it early so it passes inspection
Old May 5, 2006 | 11:54 AM
histo13's Avatar
KS replacement
Words to the wise:
How did you disengage the electrical connection that was blocking the access to the ks.I not familiar with this kind of connectionand worry that I will break it if I'm just going to pull it out.Did you disconnect all the rubber tubing.?I have a 95 gxe ,auto with 81k .I already ordered mine at Ebay
Old May 5, 2006 | 12:03 PM
histo13's Avatar
and Cali spec.
Old May 5, 2006 | 01:41 PM
jaxima's Avatar
on the connector, there is a metal clip that looks like a large staple. You need to remove this before you unplug the connector. All you need is a knife to remove the "staple". After it's removed, you can easily unplug the KS from it's harness.
edit: BTW, I replaced mine last night and I can't tell any difference yet in power but have only driven about 7 miles. The check engine light hasn't come on though, so hopefully I will feel some changes in the next few days.
Old May 5, 2006 | 01:59 PM
Maxima880's Avatar
I think he's talking about the pressure sensor control valve at the entrance to the "tunnel". Three hoses, an electrical connector, and a stud with a nut on the bottom. ***** to remove, but I had to to get my hand in there. Hardes't part is getting the nut off the bottom.
Old May 5, 2006 | 04:57 PM
histo13's Avatar
thanks! I' m going to try it when my kS arrives. If I can't , will just find somebody in RI to do it for me for $50 .I don't know if this is a fair price. If it is higher .I'll try harder until I break everything .LOL. thanks for the info.
histo13's Avatar
Old May 5, 2006 | 05:34 PM
histo13's Avatar
You are right.I am referring to those things , 3 hoses and electrical connector. Can you access the KS just by disconnecting the elec. connector without disconncecting the 3 hoses. Acoording to some it is hard to disconnect the hoses without breaking them.
Old May 5, 2006 | 07:11 PM
Maxima880's Avatar
I didn't think I could get a good shot at the opening without removing the valve. I got the hoses off with twisting and patience though they are fragile from years of heat. If you take them off make sure to put the hoses back to the original ports. mark them somehow. This valve switches the pressure sensor between ambient air pressure and manifold pressure. Your ECU could be very confused if you switch a couple of hoses by accident. If you did tear the hoses though they'd be easy to replace as they are just short hose sections between metal piping in that area.
Old May 5, 2006 | 09:35 PM
WhiteMaxima9600's Avatar
I recommend www.oxygensensors.com $60 bucks shipped, lowest I've found on tha net.
Old May 6, 2006 | 07:41 AM
bds's Avatar
bds
bought mine on ebay for about $75
bbsitum
Sep 6, 2019 07:31 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 23, 2015 08:46 PM
