Weird noise after insalling FSTB, can someone help!!!
Old May 1, 2006 | 04:32 AM
NissanMan97's Avatar
Ok so i finally put on my FSTB after i dont know how many weeks. Well no everytime i accelerate there is this 'tick, tick, tick' noise coming from somewhere. I thought maybe something was loose so i checked all the bolts and gave everything a little extra turn just to be safe they were on there and the noise is still there. Im pretty sure the FSTB is not causing the noise, but i can seem to find the problem and there is no difference in the way the car drives or accelerates. Any thoughts?
B
Old May 1, 2006 | 05:40 AM
maximaseefu's Avatar
sounds like it could be your lifters but impossible to know unless you can find out where the tick is coming from. pop your hood and give a little pull on the throttle cable and see if you can tell where the tick is coming from. it may also be usefull so you can see if it ticks while the car is not moving.
Old May 1, 2006 | 06:55 AM
Thanks but i tried that already. I cant get it to make the noise sitting still and pulling on the throttle cable did nothing. It appears to only make the noise when i am accelerating. My TOB makes noise when i am sitting still and the car is out of gear but i have never heard of a TOB making noise when you are accelerating. Im gonna take the FSTB off just to see if it stops making the noise, i doubt this will help but it doesnt hurt to try.
B
Old May 1, 2006 | 07:48 AM
azn_s3nsation87's Avatar
You driving w/ coilovers????If you are, then the reason it make that 'tick 'tick 'tick continuously when you cruise, is yur wheels bearing. I have the same problem since i got my coilovers installed, its only happen to the front bearings. I still have that noise right now, but its really annoying, am trying to get it fix asap. I shouldnt drop it too low!!!
Old May 1, 2006 | 08:03 AM
JNCoRacer's Avatar
Just the tip.
Yeah, I saw you driving down Shiloh the other day. You do sit low.
Old May 1, 2006 | 08:57 AM
I see that you have 2 Maxima, why are you selling yur 99 one? That one look nice!! I think i see you at some Nissan meets, cuz yur 99 car look familiar.
Old May 1, 2006 | 09:10 AM
Coilovers are installed yet, infact they arent even hear yet so i can be safe and say they arent causing me a problem, but thanks for the info i will keep that in mind when i install them.
B
Old May 1, 2006 | 09:55 AM
konak85's Avatar
If your FSB is thick, it may be hitting some engine components when you accelerate and the engine moves a little. especially check the evap sensor.
Old May 1, 2006 | 11:30 AM
i did some tightening and shifting here and there and the problems seemed to have stopped. If it starts up again ill go back to the drawing board. Thanks for all the help.
B
Old May 1, 2006 | 02:01 PM
JNCoRacer's Avatar
Just the tip.
Decided to keep the 99 SE. Sold the black 96 SE instead, But I still have my white 98 GLE. I saw your car at the Curly's meet last month and seen you driving a few times. Which coilovers are you on? It sits nice.
Oh, and btw, we should go hit up a junkyard sometime to get you some leather. I got my full interior (seats and door panels) for $250 good condition.
Old May 1, 2006 | 02:11 PM
dgeesaman's Avatar
Maintenance Monster
Check the AC lines that run near the passenger side pillar. They may lift and bump when the engine is under torque.
Dave
Old May 1, 2006 | 05:31 PM
Wow, nice, lets go, i want mine to be black, interior. Finally i find a Max. buddy around this area. Pm me up sometime if you have time, i'll go w/ you to junkyard.
Oh yeah, am driving on Ksports by the way. I like your 99 max, you should give it a drop, it'll look really clean.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
