Calculating value
Old May 1, 2006 | 11:21 AM
Dexter's Avatar
Calculating value
How do I calculate the current value for my 1995 MAX, what's the formula? I figure it would be handy to have this value available in case something happens (GOD forbid) and insurance company wants to screw me sideways on how much they're gonna give me. Can any of you guys fill me in on how I calculate the depreciated value? Thanks.
Old May 1, 2006 | 11:30 AM
Flava_24/7's Avatar
Boosted Panda
They normally use the current market value for you car and its options.
If you have upgrades/mods you need all your reciepts if you wish to have those added toyour cars value. You may have to have those items covered in your policy as well, i know I have them in my policy.
Old May 1, 2006 | 11:39 AM
OrestP's Avatar
www.kbb.com
www.nadaguides.com
Old May 1, 2006 | 11:51 AM
Dexter's Avatar
Originally Posted by OrestP
Thanks for the links.
Old May 1, 2006 | 07:30 PM
GodFather's Avatar
Made in Taiwan
Man, it'll be kinda hard to keep up with mine, huh?
CATTMAN HEADERS
CATTMAN CAT-CONVERTER
CATTMAN CAT-BACK EXHAUST
PLACERACING COLD AIR INTAKE
NISSAN'02 PATHFINDER THROTTLE BODY
MID-EAST VARIABLE INTAKE MANIFOLD (MEVI)
"JimWolfTechnology" 7200 ECU
"JimWolfTechnology" CAMSHAFTS (Camshafts from this company snapped 3 times already)
"JimWolfTechnology" VALVESPRINGS
NGK PLATINUM G-POWER SPARK PLUGS
SPLITFIRE DIRECT IGNITION COILPACKS
BLEHMCO'S CUSTOM GROUND WIRE KIT
DURALAST 125-AMP ALTERNATOR
OPTIMA YELLOW TOP BATTERY
SUMMIT RACING RPM SWITCH
350Z OIL PUMP
300Zx Fuel Filter
REDLINE MT-90 TRANSMISSION FLUID
BENALI NANO-PHOTON FUEL BOOSTERS
EXON MOBILE 93-OCTANE GASOLINE
MOBILE 1 SYNTHETIC OIL
MOBILE 1 OIL FILTER
STAINLESS STEEL CLUTCH LINE
MOTORSTORM UNDERDRIVE PULLEY
XTD STAGE 3 CS 6-PUCK CLUTCH
FIDANZA LIGHTWEIGHT ALUMINUM FLYWHEEL
(Stillen flywheel snapped in 2 pieces even without Forced Induction)
CUSTOM ENTERPRISE SHORT THROW SHIFTER
CUSTOM ENTERPRISE LEATHER SHIFTER BOOT
TOP ELEMENT POLYURETHANE-FILLED SHIFTER BUSHING
MAXIMA-ALTIMA HYBRID TRANSMISSION GEARS:
(TRANSMISSION IS REBUILT FROM MIXING GEARS)
FACTORY-------->NEW GEAR RATIO
1ST= 3.285-------->3.400
2ND= 1.850-------->1.955
3RD= 1.272-------->1.272
4TH= 0.954-------->0.954
5TH= 0.795-------->0.740
Final Drive= 3.823----->3.823
2 INCH DROP MAXSPEED SPRINGS
TOKICO'S BLUE STRUTS/SHOCKS
EIBACH CAMBER ADJUSTMENT KIT
J-CLAW DRAG RACE TRACTION BARS
PARADOX FRONT STRUT TOWER BARS
PARADOX REAR STRUT TOWER BARS
(CATTMAN) ENERGY SUSPENSIONS FRONT SWAYBAR FRAME BUSHINGS
(CATTMAN) ENERGY SUSPENSIONS LOWER FRONT SUBFRAME BUSHINGS
(CATTMAN) ENERGY SUSPENSIONS FRONT SWAYBAR END LINK BUSHINGS
(CATTMAN) ENERGY SUSPENSIONS POLYURETHANE CONTROL ARM BUSHINGS
(CATTMAN) ENERGY SUSPENSIONS POLYURETHANE MOTOR MOUNTS
HAWK'S BRAKE PADS
CUSTOM BLUE BRAKE CALIPERS
POWER SLOT CROSS DRIILED ROTORS
INDIGLOW CLUSTER GUAGE
BLUE LED INTERIOR NIGHT LIGHTS
SILVANIA 9007 HEADLIGHT BULBS
ALTERNATING SIGNAL BLINKERS
DIAMOND CUT CLEAR CORNERS
SMOKED TAILS
FULL CARBON FIBER DASH DRESS KIT
ANNIVERSARY EDITION SHIFT ****
DIAMOND PLATE FLOOR MATS
NISSAN EMBLEM DOOR SILLS
VIPER 350H ALARM SYSTEM
VALENTINE 1 RADAR DETECTOR
CLARION 5-SERIES MP3/CD HEAD UNIT
KENWOOD/CLARION 4-WAY SPEAKERS
WANLI DRY SEASON LOW PROFILE TIRES.
17" NEX OPT-6 ALLOY WHEELS
cjbaldw
Oct 22, 2010 10:02 AM
woreyah
Jul 8, 2002 02:50 PM
dwapenyi
May 13, 2002 07:25 PM
Cap'n Carl
Nov 24, 2001 04:45 AM
BSwithTF
Sep 26, 2001 05:24 PM
