Last straw for the vQ30DE!!!! 56k no-no
Old May 1, 2006 | 03:57 PM
tavarish's Avatar
fwd gone rwd cr00
Well, two weeks ago my car started a ticking sound (on top of the exhaust leak), so I decided to investigate. There was a coolant leak coming from the rear of the engine, so I replaced that hose, and for kicks I popped the rear valve cover.
and this is what came out:
Old May 1, 2006 | 04:09 PM
Maxima880's Avatar
WTF is that? Is it the shim?
maximaseefu's Avatar
ouch. time for a rebuild.
Old May 1, 2006 | 04:13 PM
tavarish's Avatar
fwd gone rwd cr00
No no no, 3.5's going in in a few weeks. It's been in my plans for awhile.
Scooobay's Avatar
lol it was last straw when you had the leak...or your car wouldnt start...lol airplanes hit my car and your engine just dies though matter what..
Old May 1, 2006 | 04:31 PM
BigLou93SE's Avatar
Are you putting the RWD IM on when you do the swap? Or are you going to wait, get the car running before you start messig with the 3.5?
Old May 1, 2006 | 04:43 PM
tavarish's Avatar
fwd gone rwd cr00
i'm gonna put it right when i do the swap. It'll be a bit easier, as I don't have to wire for the VI that the FWD IM comes with, all i have to do is run vacuum lines, extend the wiring for the MAF and TB, make a bracket for the throttle cable (i would have to do that anyway), and make a custom intake, not hard, i'll just buy piping off ebay, and get a cone filter.
Old May 1, 2006 | 04:45 PM
RA030726's Avatar
I'm nutty for Nissans
thats happened before. good timing for you (no pun intended).
Old May 1, 2006 | 05:20 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
You're an effing beast, man!!! Good luck!!!
Old May 1, 2006 | 07:29 PM
liqidvenom's Avatar
brotherhood of tq
holy ****...so we aint hiting the track this weekend i assume?
Old May 1, 2006 | 07:45 PM
GodFather's Avatar
Made in Taiwan
Those are your shims. you may as well go 3.5. Or else, rebuilding this engine will cost more. Good luck. I rebuilt my engine with jwt double valvesprings and new shims. i can vouch right now---go for the 3.5L engine at once. Best wishes.
-Peter-
Old May 2, 2006 | 06:55 AM
sky jumper
tavarish - could you describe the ticking? many people say a ticking/clacking sound coming from the #1 area is normal on these engines (say its the tensioner) -- you obviously had something else. what did it sound like?? where exactly was it coming from?
the reason I ask is because I recently started to notice a ticking sound. I hear it loudest from the passenger front wheel well. an oil filter change seemed to quiet it down for a little while, but now its back. thanks.
Old May 2, 2006 | 07:30 AM
Dexter's Avatar
your case sounds like the tensioner going bad (common problem) but since you mentioned that a little oil made it run better for a while I think your Oil pump could be malfunctioning. Either way have it checked before it gets any wor$$$e.
Old May 2, 2006 | 07:47 AM
motocross416's Avatar
tarvish - how many miles are on your current engine? Are you going to keep running it for a few weeks or start the swap sooner than you planned?
Old May 2, 2006 | 08:09 AM
tavarish's Avatar
fwd gone rwd cr00
i still wanna hit the track, i hope my engine blows up. I'm sick of it. I'm hittin 14's...I have to.
Old May 2, 2006 | 08:11 AM
tavarish's Avatar
fwd gone rwd cr00
i'm gonna keep it running for a few weeks, and my engine has 128k on it. All it does is make that ticking noise, doesnt really do much else, I cant really FEEL a performance loss, considering it's on the exhaust stroke anyway, so i'll leave it alone to do its own thing while i really scrounge up the dough for the 3.5
Old May 2, 2006 | 08:32 AM
bigdog97max's Avatar
Are you sure it isn't the tensioner? What you're saying describes the symptoms my car had perfectly. I was getting a ticking/clattering sound and it kept getting worse, didn't really notice any loss of power, but the noise scared the hell out of me. Now that i've replaced the tensioner (it's not just the early 4th Gens that have tensioner problems) it's completely gone and my car feels better than ever. If you haven't checked, it might be a good idea.
Old May 2, 2006 | 08:34 AM
tavarish's Avatar
fwd gone rwd cr00
did you not see the pictures? It's pretty clear what's causing the ticking.
and btw, Requin6 had the EXACT same problem.
Old May 2, 2006 | 08:45 AM
MaxGordon7's Avatar
it looks like the top of the piece that the cams push down on to push the valves open. Im sure you could replace it or it if runs don't worry about it.
Old May 2, 2006 | 06:06 PM
tavarish's Avatar
fwd gone rwd cr00
That's what it sounds like.
Old May 2, 2006 | 07:22 PM
sky jumper
yikes! yeah that's definitely not a tensioner. thanks for posting the audio clip. I wonder how the h3ll that happened? do you redline often?
Old May 2, 2006 | 08:12 PM
Requin6's Avatar
yeah thats definately the same problem i encountered....
i guess the lifters didnt like 11psi @ 7200rpms
Old May 2, 2006 | 08:15 PM
Black Maxima
Audio clip sounds like a lawn mower...
Old May 3, 2006 | 02:10 PM
tavarish's Avatar
fwd gone rwd cr00
i'd say sounds more like a tractor with my exhaust leak.
Old May 3, 2006 | 02:12 PM
tavarish's Avatar
fwd gone rwd cr00
No, I don't redline often, and I do oil changes religiously, with Castrol GTX and Mobil-1 filters at 3k.
Old May 3, 2006 | 03:14 PM
Apparition's Avatar
Ichiban King
my god that almost sounds something like a few RX7's around here, we call em weedwackers.. but man you're lucky though bro that 3.5 is gonna make you smile like never before.
litch
123
Jan 4, 2024 07:01 PM
schmellyfart
Sep 25, 2015 04:47 PM
Kevin Wong
Feb 3, 2002 12:12 AM
SteVTEC
Nov 30, 2001 02:13 PM
Nealoc187
Apr 18, 2001 05:01 PM
