Stroker crank for VQ30DE?
Old Apr 17, 2001 | 11:49 PM
Nealoc187's Avatar
SLOW
I was reading my old subscription to Super Street today, which i got when i had my honda. i happened to notice that JUN Auto Mechanic has an aftermarket crankshaft for the VG30DE that strokes it to 3.3L. i was wondering, does anyone know if they have one for the VQ30DE as well? i can not find a website for JUN, so i couldnt look there. also, i seem to remember reading that the crank from the QX4/pathfinder engine (3.4L in the old ones? is this correct?) is a direct replacement for the VQ30DE crank, and will stroke it to 3.4L. ( i will search for this article to make sure i am remembering this correctly.) any thoughts?
Neal
Old Apr 17, 2001 | 11:51 PM
Nealoc187's Avatar
SLOW
crank
the article about the pathfinder/qx4 crank was in sport compact car, roughly 6-12 months ago i believe.
Neal
Old Apr 18, 2001 | 04:57 AM
Pervis Anathema's Avatar
What kind of gains would you make with the stroker crank? Also, what other upgrades would you have to do to the engine? I am assuming a rebuild would be a good idea since the motor would have to be pulled and disassembled to swap out the cranks...
Old Apr 18, 2001 | 05:28 AM
Pmp-n8a's Avatar
250 with a 3.4L maxima has better flow
Old Apr 18, 2001 | 03:33 PM
1997 Maxima SE's Avatar
www.junusa.com
they got vg cuase its a tt engine and its acually in a sports car unlike the vq...
Old Apr 18, 2001 | 03:52 PM
Jeff92se's Avatar
I'm needing a caw
Flow is a function of the head design, not the cranklength.
Also for general information, you cannot just put a longer crank with that much longer throw and just swap it in. You will end up w/ a super high compression ratio and/or run into valve-piston clearance problems.
The modern combustion type engine is a system. You cannot change one thing internally w/o considering everything else.
Old Apr 18, 2001 | 05:01 PM
Black VQ's Avatar
Exactly
That's why to stroke the 3L VQ up to 3.5L for the current Pathfinder/QX4 applcations, Nissan had to add shorter connecting rods. This makes up for the longer throw.
litch
123
Jan 4, 2024 07:01 PM
TKHanson
Nov 24, 2018 01:39 AM
chisam14
Nov 6, 2018 08:56 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
