debadging
Old May 1, 2006 | 07:52 PM
9378max's Avatar
debadging
It's been a week since i debaged my rear end. I used a heat gun and citrius goo gone and it worked alright. after the debadging, i washed and waxed my car. problem is that my friend was driving behind me at night and he said that he could still see the white outline of the nissan emblem and maxima. is there anything else i need to do to remove this white lining?
Old May 1, 2006 | 08:01 PM
99grnmaxgxe's Avatar
It's probably just the reflection.
Old May 1, 2006 | 08:15 PM
_ck69_'s Avatar
Try using a detailing clay bar.
Old May 1, 2006 | 08:16 PM
Fr33way™'s Avatar
Wild for Width
After a couple washings and scratch-X, wax, stuff like that it will blend.
Old May 1, 2006 | 08:22 PM
BlackMaxdout's Avatar
you could also try buffing it out. I polished the trunk about 3 or 4 times with turtle wax polishing compound after I debadged mine. Then I waxed it twice. It's almost completely gone. Just takes some time and elbow grease.
Old May 1, 2006 | 08:30 PM
MaxxedOut624's Avatar
Yeh I have the same problem with where the Nissan logo was...but what do you expect its a 10yr old car...the sun has been hitting the other part of the trunk for that long. I wanna try a clay bar. Ive waxed and buffed it so many times and it still shows.
Old May 1, 2006 | 08:43 PM
whitegold's Avatar
Any change you want to sell the maxima logo?
Old May 1, 2006 | 09:10 PM
Cdg2125's Avatar
I had the same thing. After some washing, waxing, elbow grease, and some time, it'll go away. At least mine did.
Old May 1, 2006 | 10:10 PM
D-Bo's Avatar
Droppin logs
to all above. Elbow grease and time are your friends.
Old May 2, 2006 | 03:52 AM
TurTLe*'s Avatar
i had the outline for about 2 weeks. untill i got it detailed by an org member who used a PC and buffed it out easily, now you can't see any outline,.
Old May 2, 2006 | 04:37 AM
kbmaxima's Avatar
i used a rubbing compound. Then I got a pastel eraser (called Magic Rub) and went over it a couple times to see if it made a difference. It did and after that I washed, clayed, polished, and waxed.
Old May 2, 2006 | 10:16 AM
Gismo-T's Avatar
B!tch We Got a Problem
Had the MAXIMA outline left on mine, just used medium duty rubbing compound & a little wax. Left no outline or any trace it was even there!
Also my car is BLACK.
Old May 2, 2006 | 11:56 AM
19maxima97's Avatar
is it the sticky stuff on the car still or what? try using gasoline.
Old May 2, 2006 | 12:17 PM
Gismo-T's Avatar
just use a heat gun or hair dryer and peel off slowly! Careful don't heat up to much, you should have no adhesive left on. Use rubbing compound & wax, your done.
RinconI30
Jun 11, 2016 08:25 PM
mpbclutch33
Aug 25, 2015 06:23 AM
98MaXeDouT
Detailing
Jan 4, 2005 01:44 PM
jesse
52
Feb 27, 2004 07:23 AM
Magellan
Dec 18, 2003 11:15 AM
