00VI info ?
Old May 6, 2006 | 04:51 PM
MR_Maxi's Avatar
00VI info ?
I'm just about to change my knock sensor on my Oz spec 95 maxima and recall reading about the 00VI mod, Is this a worthy mod while I have the manifolds off to get to the sensor ? Has anyone got dyno proof, I can get all the manifolds quite cheap $150AUS.
I tried search and doesn't work, any info on this would be great
Old May 6, 2006 | 05:02 PM
RickRossTheBoss's Avatar
It is very beneficial, and will give you more power throughout the entire powerband, but you need more than the manifolds to get the 00vi to work
Old May 6, 2006 | 07:34 PM
MaximaSE96's Avatar
Maxima Owner
u will nned fuel rail and injectors....RPM switch ,,differernt throttle body and egr guide tube...refer to all motor section what is an OZ Spec Maxima
Old May 6, 2006 | 11:05 PM
Litowcas's Avatar
look in the all motor section!.... ull find everything u r asking for including dyno slips!
Old May 7, 2006 | 02:23 PM
PHAT6's Avatar
Hey MR - Auckland, NZ here.
We have a more local website "www.maxima.org.nz" if you car to join us mate.
Me and another kiwi are looking to install the upper and lower 00VI intake manifolds - either that or just swap in the whole VQ30DE-K engine.
SSS Automotive or Adelaide Dismantlers are
pretty good options for you.
Old May 7, 2006 | 02:35 PM
MDeezy's Avatar
very worth it, you'll finally have top end, no more falling flat on your face ~@5K.
go for it if you can get your hands on the parts
Old May 7, 2006 | 06:57 PM
BigLou93SE's Avatar
I'm surprized no one has let you know this yet - but you don't need to remove the manifolds to replace a knock sensor.
Other than that, yes, it is very worthwhile. But as I said, you don't need to remove the manifolds to get to the knock sensor - the procedure is outlined in the stickies.
Or is there a difference between US spec Maximas and OZ spec Maximas that won't allow you to replace it in the same way?
Old May 7, 2006 | 08:47 PM
GStrength's Avatar
By the way you didnt need to remove the intake manifold to replace your knock sensor. You just gave yourself a whole load of extra needless work. If your gonna put that 00vi man all i know is you need extra adapter plates. Other than that maybe you should just got with Mevi, with a rev-limiter. its way easier to install.
DR-Max's Avatar
Get yourself an extension and socket with u-joint...done!
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
