Bose Stereo (CD Error)
Old May 6, 2006 | 09:46 PM
tholitss's Avatar
My Bose head unit start giving me CD error. If i change the Bose head unit, Do i need to change all the speakers ??
Old May 6, 2006 | 09:54 PM
sdoherty_tjm's Avatar
this is a complicated thing. you need to get this one thing so that with the new HU its not amplified twice. im not sure exactly how that works. maybe someone can explain it better
Old May 6, 2006 | 09:55 PM
Nissan 6's Avatar
Fix it by yourself. The write up is in the audio stickies. You wont need to change speakers if you decide to go with a new aftermarket HU but you need some adapter stuff to run a aftermarket HU with the bose speakers. I currently have a aftermarket HU with the stock bose speakers and all is fine.
Old May 7, 2006 | 05:11 AM
dgeesaman's Avatar
Maintenance Monster
Originally Posted by Nissan 6
Fix it by yourself. The write up is in the audio stickies. You wont need to change speakers but you need some adapter stuff to run a aftermarket HU with the bose speakers. I currently have a aftermarket HU with the stock bose speakers and all is fine.
Fix the headunit, or install another one?
Anyway, if you install a non-Bose headunit, you must use an electronic adapter between the Bose speakers and the new headunit. Scosche makes one for about $55, and it works well for me. Otherwise, you would have to change out all the speakers.
Dave
Old May 7, 2006 | 06:04 AM
GoldMax99's Avatar
Dave
Would you happen to have some more great info on fixing the headunit.
Old May 7, 2006 | 09:56 AM
tholitss's Avatar
Here's the link: http://madchef.5u.com/maxima/bose/intro.html
Old May 7, 2006 | 11:41 AM
Nissan 6's Avatar
Dave
Post fixed. you got what I meant I hope.
Old May 7, 2006 | 12:19 PM
MDeezy's Avatar
Did it do it with one CD? or everysingly one?
I get a CD Err sometimes, but my CDs are dirty. A quick wipe down with my shirt and they play fine.
__________________________________________________ ____________
If you have a bose head unit now, just get any bose head unit from 95-99, and its plug and play.
Old May 10, 2006 | 02:16 PM
dimension45's Avatar
the same thing happened to me my bose cd player stopped reading cds, i was able to replace it with an alpine head unit and keep my current bose speakers. the installer is not going to like to do it but they can or just do it yourself, you will need to by some extra materials or the volume will be very loud since each speaker has a small amplifier that goes to it and the head unit you buy will probably have a small amp too, if you just go to like car toys they will be able to tell you everything
Old May 10, 2006 | 06:38 PM
Jaye_96Max's Avatar
you don't need anything special to replace your bose radio, just the standard dash kit, car reverse harness, and an antena adaptor. your speakers are playing louder because more power is being pushed through each speaker.
you dont need to bypass any amplifier
Old May 10, 2006 | 07:06 PM
chillin014's Avatar
first thing you should try is running one of those cds cleaners in there. its like a cd with a little brush attached that i guess cleans the lense. seriously, i thought there was no way that was gonna work, but it did. try it first before you tear it apart and solder and mess your headunit up like i did.
Old May 12, 2006 | 09:17 PM
GoldMax99's Avatar
Originally Posted by tholitss
Great info thanks. Too bad it doesn't go over fixing stuck cassette deck. My deck first started by spitting out tapes all the time. then it would stop ejecting them every now and then until now that it won't eject it at all. I've had a tape in there for 3 years.
Old May 12, 2006 | 09:24 PM
wootwoot's Avatar
You still use tapes?
Old May 12, 2006 | 09:26 PM
I AM A BUSINESS
Why would you want to replace your bose HU with another one? They all go through the same phase..Work good for a few weeks/months then go bad..Just do yourself a favor and buy an aftermarket CDPLAYER.
Old May 13, 2006 | 05:08 AM
max ride 41's Avatar
allright guys i'm sorry, but they should've put an "l" in front of the b to make it what it really is. nothing is compatible with the 2 ohm " blose" system because everything nowadays is 1 ohm. i put in all new jl's and a new pioneer head unit including a 6 channel jl amp with a 250 rms alpine sub. i put the component tweeters where nissan should've put them in the kicker panels next to the woofers for awesome sound. the amp has 4 ajustable crossover points and ajustable volume levels for avoiding that " flubby" sounding bass that you get with some amps. 100% improvement over stock stereo, if you have the $$$$$$$ i suggest replacing entire system, technology is way ahead of the 4 gen blose system and you will LOVE the way your max sounds with a new setup!!!!
Old May 13, 2006 | 06:43 AM
dgeesaman's Avatar
Maintenance Monster
I take it you drive with your head down at your ankles?
Fact is, tweeters work best pointing directly at your ears. Anything else loses detail. To give you credit though, you have enthusiasm to make up for it.
Dave
Old May 13, 2006 | 10:12 AM
Dave
wrong, tweeters are supposed to be close to the woofers for optimum sound qaulity. and, i hated the tweeters in my ears, i could'nt hear anything going on around me, too tinny sounding. and my new jl's are 100% better sounding so i did that because i did'nt need them in my ear anymore. going deaf man, and when you have the setup that i do you don't need to have them there. the blose system sounded halfway decent with the tweeters up there. not this one.
Old May 13, 2006 | 11:23 AM
blanquitodenyc's Avatar
TEL message
I have a 99 maxima with Bose system, and everything was working fine until this morning when I got into my car and noticed the stereo had the letters "TEL" on the display. I can't turn it on, or anything. I can still load and eject CDs. Any ideas?
Old May 13, 2006 | 05:25 PM
LeVeL's Avatar
What if you're going for a hu from another 4th gen, also bose? My guess is you can just stick it in, no need for an adapter or anything?
Old May 14, 2006 | 03:55 PM
toyick's Avatar
i got a stock cd player from a 99 i will sell ya..
Old May 14, 2006 | 04:02 PM
MDeezy's Avatar
the 99 is a beautiful unit. I have in mine and I love it, all digital, no extra ***** to break or fall off.
Old May 15, 2006 | 07:56 AM
LeVeL's Avatar
toyick - is it bose? any pics?
Old May 15, 2006 | 08:37 AM
dgeesaman's Avatar
Maintenance Monster
Which means they should *both* be pointing at your ears.
Lower tones are less dependent on direction, so if you're going to have one end of the tonal range pointing in the wrong direction, it's the low end. Given that the stock setup puts the front midrange and bass down at your feet, I boost the midrange a little bit and that compensates well enough. I doubt anyone is going to relocate the whole front speaker assembly up higher as would be the goal for real audiophiles.
Dave
Old May 15, 2006 | 09:08 AM
MDeezy's Avatar
Old May 15, 2006 | 02:30 PM
toyick's Avatar
bose yes...and my digi is broke...
leatherneck
Sep 30, 2015 09:16 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
