4th gen engine info
Old 05-08-2006, 08:13 AM
This ORG has saved me $$$$$$$$
Juicey's Avatar
4th gen engine info
Got this from:
http://your.bamawisp.net/maxima/wiki/index.php/VQ30DE
The VQ30DE became the benchmark V6 engine throughout the world making the Ward's 10 Best Engines list for many years. Though similiar in external appearance to the VE30DE from the 3rd Generation (92-94) SE Maximas, the VQ is based off an all aluminum design with microfinished internals for smooth operation.
The VQ30DE did not feature, like its older sibling VE30DE, variable valve timing. Its light-weight design, however, made up for this deficiency and was able to punch out a nice fat torque curve.
There were three VQ30DE implementations for the Maxima - US Intake Manifold (USIM), US Variable Intake Manifold (00VI), and Middle Eastern Variable Inake (MEVI).
Nissan updated the VQ30DE by increasing bore and stroke along with intake enhancement - creating the 3.5L update VQ35DE for 2002+ 5th Generation Maximas.
Specifications
* 60 degree, V6
* Valve-train: dual overhead cams, chain driven, 4 valves per cylinder
* Induction System: Sequential Multi-point Fuel Injection, variable induction
* Fuel System: ECCS
* Displacement: 3.0 liters (2988cc)
* Bore: 93mm
* Stroke: 73.3mm
* Compression Ratio: 10:1
* Fuel: Premium Unleaded (91 octane)
USIM
* Horsepower (SAE net): 190 bhp (@ 5600 rpm)
* Torque (SAE net): 205 lb/ft (@ 4000 rpm)
00VI
* Horsepower (SAE net): 222 bhp (@ 6400 rpm)
* Torque (SAE net): 217 lb/ft (@ 4000 rpm)
MEVI
(requires SAE net based information)
* Horsepower (SAE gross): 227 bhp (@ 6400 rpm)
* Torque (SAE gross): 229.4 lb/ft (@ 3600 rpm)
* Compression Ratio: 9.5:1
So how do I tell once type engine I have? From the VIN?
Juicey is offline
Old 05-08-2006, 08:29 AM
fwd gone rwd cr00
tavarish's Avatar
you have a 1998 Nissan Maxima in the US. You have the craptacular USIM. Congratulations.
tavarish is offline
Old 05-08-2006, 08:39 AM
Maxima Owner
MaximaSE96's Avatar
u have a 00vi if u have a 2000 Maxima or someone has swapped ir IM
U have a MEVI if u bought ur car from Iraq or swapped IMs
U have a USIM if u bought a maxima int he US and u car seems like it dies above 5k rpms
MaximaSE96 is offline
Old 05-08-2006, 09:54 AM
99grnmaxgxe's Avatar
Open your hood and look I like the 00vi's black color.
99grnmaxgxe is offline
Old 05-08-2006, 10:01 AM
scoobystoned...
aih98max's Avatar
gosh that makes me want to get a MEVI even more.
aih98max is offline
Old 05-08-2006, 10:06 AM
Droppin logs
D-Bo's Avatar
Go with the 00VI
http://forums.maxima.org/showthread.php?t=424641
D-Bo is offline
Old 05-08-2006, 10:49 AM
Juicey's Avatar
SWEET! What prize do I get for it being the most craptacular of the bunch?!
Juicey is offline
Old 05-08-2006, 11:44 AM
Shift_3.0
devilz05's Avatar
I can tussle your hair...and call you count crapula if you want.
devilz05 is offline
Old 05-08-2006, 03:09 PM
SMX95's Avatar
You mean like this?!?!
IS THAT A MEVI!? FTW?! WHERE CAN I GET THAT COVER!!!
SMX95 is offline
Old 05-08-2006, 03:45 PM
Ichiban King
Apparition's Avatar
.. it looks like you have decals on your mevi, the "nissan racing sport."
Apparition is offline
Old 05-08-2006, 05:07 PM
SMX95's Avatar
yeah amazing huh
SMX95 is offline
Old 05-08-2006, 05:09 PM
Zack342's Avatar
Mevi Ftmfw
Zack342 is offline
Old 05-08-2006, 05:17 PM
Ichiban King
Apparition's Avatar
yeah amazing huh
you know it haha. Still looks good budd, I like it.
Old 05-08-2006, 06:17 PM
Tyrexx's Avatar
00VI > MEVI
More area under the curve >
Tyrexx is offline
Old 05-08-2006, 06:21 PM
whitegold's Avatar
What is cheaper and easier to install 00VI or MEVI?
whitegold is offline
Old 05-09-2006, 05:38 AM
Juicey's Avatar
Ahh shucks! Does that come with a reach around?
BTW: What is that metal bar in the picture above that spans across the engine and bolts into the coil over tops? Why is that there?
Juicey is offline
Old 05-09-2006, 06:33 AM
fwd gone rwd cr00
tavarish's Avatar
Originally Posted by Tyrexx
00VI > MEVI
3.5 > 00VI > MEVI
Dwarfs the competition
tavarish is offline
Old 05-09-2006, 06:34 AM
fwd gone rwd cr00
tavarish's Avatar
Get that christmas tree lookin engine bay outta here.
tavarish is offline
Old 05-09-2006, 06:40 AM
Boosted Panda
Flava_24/7's Avatar
Front strut tower bar
Tightens up the front end to improve handling.
Flava_24/7 is offline
Old 05-09-2006, 06:41 AM
Boosted Panda
Flava_24/7's Avatar
Obviously you have never seen my red engine bay
Old 05-09-2006, 06:43 AM
Boosted Panda
Flava_24/7's Avatar
MEVI is going to be easier to install, but getting a bit hard to find. I believe Courtesy still sells them.
Old 05-09-2006, 06:45 AM
BlackMaxdout's Avatar
It's a front strut tower brace.
BlackMaxdout is offline
Old 05-09-2006, 07:42 AM
jbrocious's Avatar
it says our US compression is 10:1, does the MEVI work better with the higher compression??? i wonder why they would have dropped the compression to 9.5:1 with that intake manifold....
i would assume it would make even more power if they used the same compression.
jbrocious is offline
Old 05-09-2006, 09:19 AM
DanMaxima's Avatar
That's the same thing I was thinking...
DanMaxima is offline
Old 05-09-2006, 10:20 AM
Shift_3.0
devilz05's Avatar
Dont mislead him, its 15% performance and 85% aesthetic.
devilz05 is offline
Old 05-09-2006, 10:46 AM
MaximaDriver
WielkiWaac's Avatar
they have mevi in europe. german, austria etc. not only in iraq
WielkiWaac is offline
Old 05-09-2006, 11:18 AM
Boosted Panda
Flava_24/7's Avatar
I agree,....
Old 05-09-2006, 12:52 PM
MAVRCK's Avatar
Just about every Gen4 imported into New Zealand from Japan has the MEVI. The Gen4 that was sold new here didn't. Total difference of 29kw - just under 40 HP.
MAVRCK is offline
Old 05-09-2006, 12:53 PM
Old Maxima Legend
Ceasars Chariot's Avatar
3.5 > 00VI > MEVI > *HICCRFPOC > USIM
* hamster in circular cage running for piece of cheese
Ceasars Chariot is offline
Old 05-09-2006, 12:59 PM
Shift_3.0
devilz05's Avatar
Are you saying I should invest in a Tornado to make my car quicker?
devilz05 is offline
Old 05-09-2006, 01:48 PM
Boosted Panda
Flava_24/7's Avatar
Only if it has the upgrade,..... running hamster.
Old 05-09-2006, 05:12 PM
Shift_3.0
devilz05's Avatar
A running hamster would count as forced induction and probably yield you some serious gains. I wonder how long they can last in 95 degree summer temperatures...
devilz05 is offline
Old 05-09-2006, 05:33 PM
Boosted Panda
Flava_24/7's Avatar
You must do the Cold Air mod.........shaved hamster with ice cube on its back.
Old 05-09-2006, 05:37 PM
dot dot dot ...
NmexMAX's Avatar
Shaved Hamster FTW. Plant a fan in front of him too...
NmexMAX is offline
Old 05-13-2006, 03:39 PM
jbrocious's Avatar
anyone? insight?
Old 05-13-2006, 10:15 PM
Made in Taiwan
GodFather's Avatar
According to the info from Post #1, it says that mevi puts down 5 peak hp and 12 peak tq than 00vi. How in the world is that possible? I thought we've already shown enough dyno maps that 00vi dominates mevi everywhere. Dude, weak. I was getting ready to do a 00vi conversion soon. Now this is really making me puzzled.
GodFather is offline
Old 05-14-2006, 11:06 AM
DanMaxima's Avatar
Well, considering how much money were talking about for a 00VI or MEVI, why not just look for a steal deal for a 3.5 from a junkyard and do a total conversion?
Old 05-14-2006, 05:24 PM
nismology's Avatar
You've got it backwards.
nismology is offline
Old 05-14-2006, 05:29 PM
Ichiban King
Apparition's Avatar
just out of curiosity are you running 00vi nismology?..
Old 05-14-2006, 05:35 PM
nismology's Avatar
Nope. Had a MEVI a while ago but sold it. Car is currently totaled. Got my eye on a sterling mist SE-L. A few local orgers are running the 00VI though.
Quick Reply: 4th gen engine info
