Cleaned TB, now i got hesitation
Old May 9, 2006 | 09:49 AM
Mr Willis's Avatar
I cleaned my TB the other day and ever since my car hesitates when i hit the gas. I noticed some ripped rubber around the MAF where those clamps are(the ones you tighten with a screw).
Question 1: Would a TINY intake leak cause severe hesitation while accelerating?
Question 2: If so wouldn't it also hesitate while hitting the gas in park? because it doesn't do it in park.
Old May 9, 2006 | 09:58 AM
Mr Willis's Avatar
http://i46.photobucket.com/albums/f145/hypr004/MAF.jpg
this is where the ripped rubber is.
Old May 9, 2006 | 10:41 AM
cardana24's Avatar
Blown
yes, that leak is after the MAF it would cause problems if you are taking in air from that point. Put a peice of duct tape over it and then crank the car, it should run fine. If that fixes it then you just need to get a new rubber peice.
Old May 9, 2006 | 10:58 AM
Mr Willis's Avatar
is that rubber circle part of the MAF? part of that black box? OR, is it an independant piece? Autozone didn't know.
Anyone have the answer to this?
Old May 9, 2006 | 11:00 AM
Mr Willis's Avatar
I think you're absolutely right. Now i need to figure out where to get it and what it's called.
Thanks man!
Old May 9, 2006 | 11:18 AM
99grnmaxgxe's Avatar
I think that rubber part is just apart of the stock midpipe, just tape that biatch up and see if that stops the hesitation, report back like a soldier!
Old May 9, 2006 | 01:15 PM
cardana24's Avatar
Blown
Thanks man!
No problem. If you do want to replace that part, I would just go to the dealer, I am guessing its not that expensive, and I doubt that is a part that you can get at a parts store. You may also look thru the parts f/s section, someone may sell you one. I may actually have it, if you have a better picture of the part rather than that far away one. I have not had a stock intake set up on either one of my cars in such a long time I don't really remember what you are talking about.
Old May 9, 2006 | 01:34 PM
super6's Avatar
if its not the air leak its likely the tps sensor. did u disconnect while cleanning? if so thats your problem, it needs to be set to 500 ohms.
Old May 9, 2006 | 02:41 PM
Mr Willis's Avatar
What's a tps sensor? I'm a noob. Thank's in advance
Old May 9, 2006 | 02:45 PM
Mr Willis's Avatar
I taped it up with electric tape but i need to buy some duct tape. It may have helped it a bit but i'm not really sure because the hesitation happens intermittently. I'll let you guys know if the duct tape works. For some reason i think it will.
Old May 9, 2006 | 04:23 PM
PHAT6's Avatar
It's a real shock what a small leak or gap in the connective tubing/piping between the throttle body and the POD filter (air box) does to a Maxima.
Old May 9, 2006 | 06:56 PM
1991tsi's Avatar
Old May 9, 2006 | 07:03 PM
Mr Willis's Avatar
Originally Posted by 1991tsi
GOOD FIND number 12 number 12. er? i think.
Box 9. I bent the crap out of everything in box 9 to get to the Throttle Body.
Old May 9, 2006 | 08:56 PM
Why did you bend it? Should of taken the whole intake off, really easy.
Old May 9, 2006 | 09:53 PM
Mr Willis's Avatar
I didn't bend it all permanently, only while i was trying to take off piece 10 on the diagram. But I later realized what you just said. Take off the whole intake. LOL!
Old May 9, 2006 | 10:00 PM
If it's something expensive to replace, or not worth replacing, I would just get an Ebay intake.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
