When I depress my clutch it sounds like an old mattress.
Old May 13, 2006 | 01:05 PM
Fr33way™'s Avatar
Wild for Width
When I depress my clutch pedal I get this old squeaky mattress sound. I don't hear it very much when I am driving but I am not sure that it gets any quieter it is probably just masked by other noises.
What areas can possibly be causing this sound?
It is not the pedal itself as the noise is very faint with the windows up.
Thanks for any help, I am going to try in get the car in the air in the next couple of days and have someone work the clutch, I would just like to have a couple ideas before I get started.
*edit* BTW I have an ACT stage 1 clutch.
Old May 13, 2006 | 02:04 PM
Mr Willis's Avatar
I certainly don't know much about car's in general. But a squeaky mattress is from the old spring's. I'm sure clutch's use spring's to bring back the pedal when u depress the clutch. Find it and probably just oiling it would do the trick or replace it.
Old May 13, 2006 | 02:22 PM
96blkonblkse's Avatar
mine does that but its my seat that sqweaks lol..
Old May 13, 2006 | 02:46 PM
Fr33way™'s Avatar
Wild for Width
The sound is not from the interior.
Mr. Willis I was thinking of a return spring for the pedal (on the other side of the firewall) but I suppose we will see in the next few days.
Old May 13, 2006 | 03:04 PM
MadMaxSE-L's Avatar
Doggah Bite...
I have this same exact problem- vut mine sounds like the noise is comming from rubber boot on the transmission where the slave cylinder pushes at...
Old May 13, 2006 | 08:38 PM
acidspit86's Avatar
ya its the pivot that the throwout fork pivots on when you hit the clutch. its just a metal ball on the other side of the bellhousing, and its running dry of grease, AFAIK, the only way to fix it is it remove the transmission and regrease it, mine does the same thing, and so did my 91 maxima...
Old May 13, 2006 | 09:11 PM
200kMax's Avatar
if i recall, almost all of my clutch's on other cars made this noise and the cause is a rubber bushing at the release boot that gets worn. best way to fix is to get in there and lube it up.
Old May 14, 2006 | 02:03 AM
99se5speed's Avatar
SHIFT_up
Wow this thread is just in time, i'm about to replace my clutch and all the parts that go with it so i'll be looking for that bushing. Btw is it just regular grease or something special?
Old May 14, 2006 | 02:08 AM
Digital's Avatar
VIP
I just have a squeaky clutch pedal. heh
I gotta hit it with some WD-40 or somethin.
Old May 14, 2006 | 05:46 AM
Keatz's Avatar
I got the same problem, nothing a little lube cant fix
Old May 14, 2006 | 09:51 AM
acidspit86's Avatar
its right under the throw out fork, its just a little ball that it snaps over. pull the fork off of it and put some high temp grease on it, make sure you get enough on, but not dripping off, you dont want that grease ending up on the clutch...
Old May 14, 2006 | 02:18 PM
Fr33way™'s Avatar
Wild for Width
That's the hope but if it is INSIDE the bellhousing it's going to squeak on.
Old May 14, 2006 | 07:35 PM
White90's Avatar
I've got the same problem.
Old May 15, 2006 | 12:57 AM
Trajiksmax's Avatar
Proud Maxima Owner
I did what was mentioned above, used some High Heat grease. I Did the best I could w/ the High Temp and then sprayed a little WD-40 in their. Sound is gone!!!
Old May 15, 2006 | 05:07 AM
nismos14's Avatar
§č~® f®ČÄk
If it is only with the clutch down all the way then it could be the input shaft bearing.
Old May 15, 2006 | 02:22 PM
MDeezy's Avatar
I had a similar like sqeek, but it was the spring by the firewall that was creating the noise, some greese and the noise was gone. If the noise is comming from the exterior of the car . . . some work will be needed to be done.
Old May 15, 2006 | 03:02 PM
Fr33way™'s Avatar
Wild for Width
I really think it is the firewall, can you PM me a pic or anything helpful of what you lubricated Marlon?
Old May 15, 2006 | 03:04 PM
MDeezy's Avatar
I'll run out and take a pic now.
Old May 15, 2006 | 03:16 PM
MDeezy's Avatar
When I spayed my greese (lithum greese) I kinda sprayed the general area but I'm sure when it hit that spring, that cured the noise.
Had to take that pic upside down under my steering wheel . . . man there isnt much space to snap a pic!
Old May 15, 2006 | 05:20 PM
Fr33way™'s Avatar
Wild for Width
I looked in the FSM and that was the peice I was thinking, thanks for the pic.
Old May 15, 2006 | 05:26 PM
MDeezy's Avatar
no prob........
Mahmuth
Aug 16, 2024 08:23 PM
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
