Longer wheel studs
Old May 14, 2006 | 08:17 AM
maxihari77SE96's Avatar
Longer wheel studs
How hard is to add these (for the 15 mm spacers) in the back?
Is there a write-up - stickie?
thx
Old May 14, 2006 | 09:07 AM
Shannon and Ian's Avatar
Knock them out with a hammer. Put on the reverse. Just make sure you get Nissan studs with the same shoulder or else it will not seat and be a PITA to remove with the lug nut spinning. I know from experience as I have just gone thru this with H&R studs......
http://www.sr20forum.com/showthread.php?t=156008
Old May 14, 2006 | 09:17 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
The best, and easiest way to do this is to use an impact gun to put the new ones one. Nock out the old ones with a hammer, and then tap the new one slightly into the hole and then use a lugnut and impact gun to press it in. Using a hammer to pound the new one in is a pain in the ***.
Old May 14, 2006 | 01:38 PM
maximaintheface's Avatar
even if u dont have an impact gun u can use a tire iron to pull the bolts out.
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
