reset TCM or ECU?
Old May 15, 2006 | 07:13 AM
sky jumper
reset TCM or ECU?
maybe a stupid question - is there such a thing as resetting the TCM? if so, how? I've read a couple posts about resetting the ECU after putting new/different ATF in (to re-learn the shifts). but I thought the TCM controlled the shifts, not the ECU, or are they one in the same?
Old May 15, 2006 | 07:36 PM
sky jumper
bump. anyone?
Old May 16, 2006 | 03:41 AM
njmaxseltd's Avatar
The TCU doesn't learn, it's shifts are mapped, they don't change.
There is nothing to "reset", you can only clear error codes from your ECU.
Old May 18, 2006 | 12:10 PM
stoneman's Avatar
I have my 95 SE at the transmission shop now, they said trans. is good, but I need to replace the ECU. I thought there were 2 units, a trans. control unit and the ECU. Please help! And is this something I can do!
Old May 18, 2006 | 12:37 PM
Jime's Avatar
There is an ECU and TCU, find out which one. Probably the TCU. Yes you can do it yourself, one plug like the ECU held in with a 10 mm bolt and its located behind the ashtray just above the ECU. Not sure how many screws/bolts hold the TCU in place but its a pretty simple job.
Old May 19, 2006 | 11:37 AM
stoneman's Avatar
Thank you Jime. That's what I needed to know.
Old Jan 16, 2007 | 01:10 PM
eilison's Avatar
Hi, folks,
My auto trans also has slips from 1st shift to 2nd and from 2nd to 3rd shift. How do I make sure I need a new TCM instead of a new AT?
If I need a new TCM, how much is it and where to get it?
Thanks!
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
Colossus
Sep 9, 2015 05:46 AM
