Serp Belt replacement
Old May 15, 2006 | 06:02 PM
BobMax's Avatar
Can someone give me a pointer to instructions for this ? Is this a PITA replacement or a gimme ?
Old May 15, 2006 | 07:44 PM
bhmax16's Avatar
gimme....loosen nut on tensioner pulley (14mm I believe) then use a 14mm socket on the tensioner assembly to loosen the belt. Take off belt, route the new belt on correctly, tighten the tensioner assembly so the belt is at a similar deflection to the old belt, tighten the 14mm nut on the tensioner pulley. Done
5-10 min job tops
Old May 16, 2006 | 08:48 AM
MaximaSE96's Avatar
Maxima Owner
for the NOOB to serp belts..there are 2 on our cars....and it takes a lil more than 10 min if he has no clue what he is doing
Old May 16, 2006 | 01:13 PM
darklegend06's Avatar
Do you have a place to work on your car? Are you capable of using tools and knowing which tools to use? DO you have a repair manuel like chiltons or hays? <--- this will help you a lot. Over all if you have all three of these it's a gimme repair.
Old May 16, 2006 | 03:14 PM
dgeesaman's Avatar
Maintenance Monster
The power steering pump belt is definitely more tricky. You have to loosen the pump pivot bolt in addition to the tensioner adjust and bracket bolt. The pivot bolt is hidden behind the pump.
Dave
Old May 16, 2006 | 03:59 PM
maximaintheface's Avatar
ya it took me about 30-40 mientes to do both just beacuse the power stearing belt was kinda tricky but its not hard at all to do i took of my front tire to give me alot more room.
Old May 16, 2006 | 06:40 PM
Fr33way™'s Avatar
Wild for Width
Originally Posted by bhmax16
5-10 min job tops
No. I hate when people give such ridiculous numbers.
It is not difficult, but you can't exactly do it over a commercial break.
Old Jun 5, 2006 | 05:03 AM
BobMax's Avatar
Thanks all, sounds reasonable.
Old Jun 5, 2006 | 05:23 AM
matty's Avatar
5-10 min job tops
and an oil change takes 1-4 minutes..hahahah
Expect to spend about a half hour on it. If your changing your power steering belt as well, thats a bit more difficult. You need to loosen the adjuster on the pump on the top, then youll need to get up underneath by the Y-pipe and loosen a 14mm bolt that drops the entire pump down a bit. Kinda a pita.
-matt
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
boomerbrian
Sep 4, 2015 08:25 AM
