midas ftl
midas ftl
ok well i just took my front caliper off for the first time since midas re fixed it. first of all it fell off on the high way. ok so get this. the bolt that fell out last time that they said i messed with some time before... i never did. anyways they put the wrong size in again !!! its way to small the only reason it stayed in was because they used a bunch of locktite. not just that there are no shims on the brake pads. all the hardware is really really bent up and some is missing. wtf they are such *** holes. then when i call them they try and charge me and say that its not under warrenty.. lifetime warrenty my ***. well i just orderd a brake hardware kit that should be coming in today. but where can i get shims? i know that is probably why my brake makes a clanking sound.
Wow very interesting story there. Some brake pad comes with shims, and some are just built into the pad. Good luck to you on those brakes. Next time you should do it yourself. Its very easy if not there must be someone around you that can help you out.
The brake hardware kit comes with shims and anti rattle springs. Actually, there isnt anything else in that package. OEM pads dont have shims on them but some aftewrmarket ones do. Aftermarket shims are not clipped on like OEM ones. They are attached with the same rivet that holds the steel backer. If you look closely at a HAWK HPS Pad, you will see the stell backer has a plastic piece on top. That is a shim. If you try to put OEM shims on a Hawk HPS you cant get the caliper on. (I know I tried) .. and I broke the shim off the pad trying. In the hardware kit is a small stainless shim that clips on the back of the one pad on the piston side so that the piston wont muck up the plastic shim.
Anyhow, Your Caliper mounting bracket might be screwed up. The bolts appear to be hard enough to strip that bit no problem. Especially with these jokers who overtourque the crap out of everything.
These places like Midas are just traps. They get you in there with a cheap price and a promise to do the job in 15 minutes or whatever. Then:
"Oh. While we were (fixing the brakes / changing the oil / whatever) we found these things that need urgent attention or (you're going to crash / be arrested) and they present you with a $500 list.
In once had to get my brakes fixed in a hurry in the U.S., wasn't at home where I could do it myself, and they basically blackmailed me by taking stuff off - the caliper piston - and then saying it was worn out and couldn't be put back on. Don't go to those places, they are just sucker traps. I put Pep Boys in the same category. Or worse.
i highly reccomend doing them yourself i did all 4 with pads and rotors, and i replaced my rear calipers in 2 hours. its really easy just some people would rather not get your hands dirty. and yes midas FTMFL i dont trust any of those places..
ya i actauly did the brakes on my toyota and my brother eclipse. the reason i had it taken in was my cars brakes were so shot and i was working 60 hours a week. at the time i saw paying a few hundred bucks alot better option then working on my car lol. i usaly do all the work myself brakes are cake. ive done them a few times. i just didnt have the time. thanks for the support guys i just about lost it with the whole crew at midas then i just left because it does no good to get angry at them it wont make them fix thier problems.
Originally Posted by maximaintheface
ok there excuse is the calpier is old. and also the brake pads dont come with shims now a days. and also my caliper fell off because it was old.
When I was looking at the car I have now, I took it there for inspection....
Basically all they did was literally tell me to my face that there is a lot wrong with the car and the reason behind it is because it is a Nissan.
WTF!?? The last time I ever goto Pep Boys.
Maximaintheface, just get your stuff and do the brakes yourself. It's a straightfoward process.
lol ive said like 4 times already i did them myself. i just finished them it took mabye an hour and a half replaced the brake hardware a caliper and blead the brakes. also took it for a test drive and broke them in a little i need to bleed them again then go on the highway and raelly brake them in .
Turbonut
46
10-21-2015 08:28 PM
95maxred
06-10-2002 05:00 PM
