Rusty Exhaust Tip
Old May 19, 2006 | 03:00 PM
Rotncarcas's Avatar
Rusty Exhaust Tip
I dont have a welder, and have never welded. My exhaust tip is completely corroded and shelling apart. The muffler attached to it is pristine, but it is attached by a weld. What is the most economical way for me to get a new tip on there. (BTW I would prefer near stock sound and look)
Thanks in advance
Old May 19, 2006 | 03:03 PM
BlackCat's Avatar
RIP '98 Maxima SE
I'd pick up a new tip and have a muffler shop weld it on.
Old May 19, 2006 | 03:04 PM
1996blackmax's Avatar
Is this the OEM muffler? Mine slides off if I pull hard enough. I replaced mine with one from another 4th gen in the junkyard. Maybe you could only do this with the older 4th gens.
Old May 19, 2006 | 03:05 PM
Rotncarcas's Avatar
How much would a muffler shop charge me? Anyone have a relative idea?
Old May 19, 2006 | 03:06 PM
ChasMan's Avatar
Are you talking about the chrome extension that Nissan press fits on and then uses a tube expander to connect it? If so, it has little effect on the sound. When my muffler went, I bought a factory exhaust and the tip was an extra 80.00. I couldnt attach it. They had a special tool sort of like a flaring tool at the dealer they used to attach it. In your case, they would have to cut it off, then add a section of straight pipe and fit a new tip onto that. Any good shop could do that for you.
Keatz's Avatar
well a tip doesnt effect the noise, and i would say head to autozone or even walmart, grab a stainless steel tip and go to a muffler shop n tell em to weld it on, wont cost u much
Old May 19, 2006 | 03:10 PM
Rotncarcas's Avatar
I think its the oem muffler, but I have my doubts about the oem tip. It lived in idaho and oregon, so rust doesnt happen. Only a 99.
Old May 19, 2006 | 03:12 PM
Rotncarcas's Avatar
It used to be stainless steel i bet, it does attach to the thinner pipe coming out of the muffler. The thinner pipe is in good condition.
99grnmaxgxe's Avatar
Labor would probably be around $20 and the tip should be less than $10. I have a bolt on from Wal-Mart for only $11.
Old May 19, 2006 | 03:48 PM
JNCoRacer's Avatar
Just the tip.
I picked up a bolt-on tip for $15 at Autozone that I put on my stock muffler. I wanted something that looked kind of stock but just a bit bigger. Now when I put the stock muffler on with my trailer hitch it doesnt look pea-shooter-ish.
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
