Mods question.
Old May 21, 2006 | 04:10 PM
soontobe's Avatar
Mods question.
I know this is debatable, but I want to get some opinions before I spend my hard earned cash. I have a 1995 stock GLE. First on the mod list is a suspension followed by rims and tires. I am leaning towards H&R springs paired with Tokico Illuminas. Comments on this pairing? Pros Cons?
As for wheels, I am DEFINATELY going with Axis Hiro's 18x18.5, offset 45mm wrapped with Toyo Proxies 4. Now for the tire question. I'm wanting go go with 245/40/18. On Tirerack, it is recommended to get tires that are 235/40/18. With this wheel size, offset and tire size will they stick out too far? Any rubbing issues that any of you forsee?
Finally, Does anyone have pics of this setup on a 4th generation they can post? I've seen the 5th generation on Axis Hiros, but I can't locate pics on a 4th.
My car is the silver metallic with a purple pearl with black leather. (I think it's fairly rare, I haven't seen many). I plan on posting pics along the way so everyone can check it out. I appreciate any comments..........
Old May 21, 2006 | 08:44 PM
FantasyGod's Avatar
Unless your shocks are worn out right now, hold off on the suspension. Don't fix what isn't broken. Same with wheels and tires, wait until you have tires that are worn or have a broken belt deserved to the be replaced, likewise wait to replace wheels unless cracked. Either reason is reason enough to get a new set of wheels and tires.
Old May 21, 2006 | 08:53 PM
JNCoRacer's Avatar
Just the tip.
Um he wants to mod his car.
Unless the struts are blown or weak I dont see a reason to place them just yet with the H&R's. However if you spend the money on the struts and do the springs and struts at once you'll save a bit of time and money working on it and getting alignments.
As for the tire and rim question...Nice selection with the Hiro's. Those are some sharp looking wheels. You shouldnt have any problems fitting a 245/40 on there with that offset. I think the mods you're looking at are good choices. Cant wait to see the results. Post pics when you can.
Old May 21, 2006 | 09:28 PM
Turbo1er's Avatar
Doin' it 4 da shorteez
Without lower springs for the wheels he will likely have a 4x4 look.
I heard H&R were good, I had S-techs and Illuminas on both my 4th Gens and they were great but still gave a gap for 17"s.
Old May 21, 2006 | 09:41 PM
ImmaSquashYou's Avatar
i use my stock rims and tires in the winter. If i use them up and THEN get rims, i'd have ot get new tires for those also...
Old May 21, 2006 | 09:59 PM
MainSource's Avatar
Hit 'em with the stun gun
I know there are a couple of 4th gen'ers riding around with Hiros. I definitely like them, and have considered putting them on my car. It'll definitely look really hot with the drop and the rims.
I started looking for pics, but I can't find them now. I'll continue searching tomorrow.
Old May 22, 2006 | 01:04 PM
samito's Avatar
the right size for your car would be 2254018 the other two would work but it will throw off your speedometer-i have seen 2454018on a 4th gen way to much sidewall
Old May 22, 2006 | 01:13 PM
JNCoRacer's Avatar
Just the tip.
225/40? a little narrow dont ya think? Hell even Tirerack reccommends at least 235/40. He'll be fine with 245/40's. Thats what he wants anyway.
Old May 22, 2006 | 01:31 PM
MainSource's Avatar
See here for pics of Maxima with Hiros.
http://forum.maxima.org/showpost.php...4&postcount=52
Old May 22, 2006 | 01:40 PM
Radiohead's Avatar
I have H&R Sports with Tokiko Illuminas on my SE. I don't have Hiros, but my wheels (17") still have 5 spokes, so just use a little imagination
Close up of wheel gap in front:
Also, the ride quality is alright. It's a bit harsh over bumps and railroad tracks, but they have a very nice firm feeling to them.
Old May 22, 2006 | 06:03 PM
soontobe's Avatar
Thanks for all the responses and thank you MainSource for hunting down some pics for me to look at.......VERY much appreciated. Any more comments? Does anyone else think that at 245/40 is too much tire? Should I go with 235/40?
Old May 22, 2006 | 06:49 PM
scalawagd's Avatar
radiohead, that drop looks very nice. hope this is not too OT, but I was wondering if you have any trouble scraping with steep inclines in driveways, etc.
I have to be really careful with scraping in my lowered prelude. I am getting a Maxima soon and it seems like the HR Sport is a nice drop without being too slammed. how much finger gap is there?
thanks
Old May 22, 2006 | 07:00 PM
NmexMAX's Avatar
dot dot dot ...
On an 4A A32.. Hiros in that size will make you holeshot like a Civic... especially at 4200' elevation. But they will look good with 245/40-18. 45mm offset will not sitck out.
Illuminas with any spring combo is good since they're adjustable.
Old May 22, 2006 | 10:24 PM
245/40 is not too much tire, but will make the 18's look like 17's. 225/40/18, you'll have a MUCH BETTER CHANCE of denting your rim. Much safer to go with 235/40 and even better with 245/40, but again, it will make ur 18's look a lot smaller
Old May 22, 2006 | 10:56 PM
Radiohead's Avatar
thanks
Thanks! I'm not sure how much finger gap I have, but it looks a lot less because my Maxima is black. Does a good job at hiding fender gap
Also, I have absolutely no problems scraping, even on my driveway, where I have to go up a 40-50 degree incline ramp
Edit: I guess I should add that I BARELY make it up that ramp
Old May 23, 2006 | 06:09 AM
NmexMAX's Avatar
dot dot dot ...
245-40 will close the wheel gap slightly more than 235-40.
It(245-40)will be .3165" taller.
Old May 26, 2006 | 01:04 PM
soontobe's Avatar
NmexMaX: Don't want to sound like a moron, but what does, "On an 4A A32.. Hiros in that size will make you holeshot like a Civic... especially at 4200' elevation" mean? I don't want my Max to look like a POS Civic. Also, I now live in Las Vegas, NV.
Old May 26, 2006 | 04:25 PM
NmexMAX's Avatar
dot dot dot ...
On a 4 speed automatic(4A) 4th generation Nissan Maxima(a32) equipped with a VQ30DE engine, your initial take off(launch, holeshot, etc) will suffer due to the heavy weight of those wheels and the lack of sufficient stall speed and slight torque deficient engine. This situation will be much more prounced at a higher altitude where normally aspirated engines (N/A) suffer due to lower atmospheric pressure.
So as far as looks, it wont be as bad. Seems as if you're more into looks, so never mind what I sad.
Old May 26, 2006 | 07:21 PM
soontobe's Avatar
I appreciate the insight. I'm not necessarily interested in looks, I'm interested in performance followed by looks. I do like the looks of this wheel, but in no means don't want to hinder performance. I found the specs on the Axis Hiro. Each wheel is 22.4 lbs. Is this considered to be heavy? Also, I plan on doing a BBK as part of my project.
Old May 26, 2006 | 07:31 PM
mendon99's Avatar
tastey wheat
hahaha
doctorpullit
Mar 29, 2016 11:08 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
pears
Sep 18, 2015 05:25 AM
