Brake problem
Old May 21, 2006 | 07:48 PM
ghdtpdna's Avatar
Brake problem
I was told that I need to change rear brake pads and that I should use OEM since and how much would it cost and if OEM is really necessary.
Old May 21, 2006 | 08:06 PM
lee's Avatar
lee
oem is not necessary, any brand will work.
Old May 21, 2006 | 08:52 PM
FantasyGod's Avatar
Probably would want to just do it yourself. VERY easy. Tools needed: Metric Socket set, C-clamp. Hawk HPS pads are nice.
After you get the wheel off, locate the (2?) mounting bolt that hold in your calipers. After the the calipers are free, remove the shims and and old pads. Inspect your rotor for cracking and warping, get them resurfaced if necessary. Pop open the hood and open up the master brake cylinder. Then use the c-clamp to press the pistons flush with the rest of the caliper and install new pads and shims. Remount caliper and wheel. Done.
Old May 21, 2006 | 09:47 PM
MainSource's Avatar
Hit 'em with the stun gun
OEM is not necessary, it is a matter of preference. Some people prefer OEM because of low dusting and noise. It's all in what you desire.
Old May 22, 2006 | 03:58 AM
njmaxseltd's Avatar
Originally Posted by FantasyGod
Then use the c-clamp to press the pistons flush with the rest of the caliper .
Thats not how you compress rear calipers. The piston turns clockwise to compress. You can rent the tool at Autozone or just purchase one to make the job much easier.
Old May 22, 2006 | 03:57 PM
bkmax96's Avatar
lol i found that one out the hard way on my 2002...i bent a c clamp trying to depress the caliper....used some channel locks.turned it clockwise n badabingbadaoom...i felt like the biggest *** evarrr!!!
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
slowlifer
Sep 8, 2015 05:53 AM
