Fog Housing HIDs
Old May 24, 2006 | 08:13 AM
Tatanko's Avatar
Bacon Lover
Fog Housing HIDs
I don't think I've ever heard why, even after searching...what is it that requires us to use micro H3 HID bulbs in our fog housings? Space, I assume, but what's the reason for the lack of space? Is it the glare shield?
I'd love to grab a 3000k H3 kit off eBay since they're so ungodly cheap, but I want to know this.
Old May 24, 2006 | 12:00 PM
Tatanko's Avatar
Bacon Lover
Surely someone knows...
Old May 24, 2006 | 12:20 PM
JNCoRacer's Avatar
Just the tip.
Yes its the glare shiels that gets in the way. I was able to heat up and disassemble the ebay replacement fogs to remove the shield but the factory fogs have to be cut open. Even after removing the glare shield the bulb was really close to the glass lense. Everything is doable with patience.
Old May 24, 2006 | 12:34 PM
Tatanko's Avatar
Bacon Lover
The shields do bend, I know that. I've bent my own for various reasons before, and you can bend them upwards quite a distance. I don't feel like cutting mine open, but if I bend it up far enough, could I possibly make the bulb fit without actually REMOVING the shield?
Do you have fog HIDs then? I take it you must have the regularly sized ones?
Old May 24, 2006 | 04:37 PM
ch13f's Avatar
the shield is there to properly distribute the light, im pretty sure the optics are gunna be all distorted without a shield, better off going with the micro h3
Old May 24, 2006 | 08:22 PM
86maxima96's Avatar
I Broke OT
link to cheap kits? i see some for $200ish. hoping you see some cheaper?
Old May 24, 2006 | 11:34 PM
FantasyGod's Avatar
Why Nissan chose H3? H3 is a compact package, comprised of a VERY short bulb and a power flexible power wire instead of prongs.
However, since H3 utilizes a horizontal type filament, there aren't any powerful halogen replacements and the D2S has a completely different focal point compared to the H3. H3 HID kits generally do not perform well at all. The only decent HID kit that had a somewhat similiar focal point to the D2S are the H7, H9 and the H11.
Old May 25, 2006 | 03:49 AM
Tatanko's Avatar
Bacon Lover
Unfortunately I was mistaken I don't even see the $200-ish ones actually
Why did they use 9004 for the headlights
Old May 25, 2006 | 08:57 AM
FantasyGod's Avatar
Dunno. I think the Maxima was designed just as the H4 was gaining popularity. Maybe Nissan didn't want to redesign their headlight over a bulb change. Also the 9007 started picking up around the same time too.
Old May 25, 2006 | 10:08 AM
MorpheusZero's Avatar
Wait.
You're going to buy a fog HID kit... AND THEN REMOVE THE GLARE SHIELD?
Old May 25, 2006 | 10:19 AM
alpinestars™'s Avatar
THIS IS...
Link to said kit, or die.
Old May 25, 2006 | 11:11 AM
tikiboom's Avatar
I need an intervention
Do regular-sized H3 bulbs create more output than micro-H3 bulbs?
Old May 25, 2006 | 05:22 PM
maxgtr2000's Avatar
KH3 by popular demand
http://www.hidplanet.com/forums/view...=7340&start=40
Cortesy of org member Meanbean.
Old May 25, 2006 | 05:47 PM
Tatanko's Avatar
Bacon Lover
Look at my reply above
Old May 25, 2006 | 05:48 PM
86maxima96's Avatar
I Broke OT
Originally Posted by MorpheusZero
Wait.
fogs can be aimed, so i don't think it's totally out of the question...
86maxima96's Avatar
I Broke OT
Was this low low price a Buy It Now price, or a starting bid (no reserve, I'm assuming)?
Old May 25, 2006 | 07:05 PM
Tatanko's Avatar
Bacon Lover
Buy it now...but it said "kit" in the description and ended up being nothing but a pair of capsules. Yes, over $100 for a set of capsules.
Old May 25, 2006 | 07:53 PM
Yes, fogs can be aimed, but changing the beam pattern and then reaiming them not to blind anyone would but very little useable light on the road.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
