Car Alarm Rondomly Going Off
I have a 99 SE and my car alarm has been randomly going off (with the car parked and armed) the past 6 mos or so. It seems more frequent lately. It happens at night, day, wet weather, dry weather. THere doesn't seem to be any pattern. Has anyone had this problem, or does anyone have any ideas how to diagnose / fix it?
Thanks.
Thanks.
Sorry, I thought they all came with factory alarms. It is a factory alarm, no motion sensor or shock. The horn just blows if the doors are opened while it is armed. I don't even think it uses voltage drop, I think has has a switch on the door jam.
Unplug the switch in the trunk and if your alarm doens't go off, theres your problem.
Classification:
EL98-005
Reference:
NTB98-054
Date:
June 15, 1998
Subject:
1995-98 MAXIMA SECURITY SYSTEM FALSE ALARMS
APPLIED VEHICLES:
1995-98 Maxima (A32) SE models only
APPLIED VINS:
JN1CA21A6WT308121
JN1CA21AXWT405211
JN1CA21D5WT531065
JN1CA21D1WT615349
JN1CA21D*WM924510
JN1CA21A*WM806675
APPLIED DATE:
Vehicles built before March 10, 1998
SERVICE INFORMATION
If an applied 1995-98 Maxima (with spoiler) has intermittent false alarms from the security system, the cause may be corrosion on the trunk lid lock assembly. If water leaks through the groove in the spoiler spacer and drips onto the trunk lid lock assembly, the switch on the lock assembly could become corroded and cause intermittent short circuits sending a false "trunk open" signal to the body control module (BCM). Because the BCM would think the trunk is open, the alarm would sound.
Use the following procedure to diagnose and repair this incident.
SERVICE PROCEDURE
1. Open the trunk. Remove the inner trunk lid finisher and plastic lock assembly cover (see Figure 1).
2. Unbolt the trunk lid lock assembly from the trunk lid. Leave the wires connected.
3. Push the lock mechanism to simulate a closed trunk (see Figure 2.)
4. Make sure all doors are closed. Push the LOCK button on the remote transmitter to arm the system.
5. Look for the red LED security system light on the dash to verify the system is armed. The LED should blink once every 2.4 seconds.
6. Tap the lock assembly switch and/or wiggle the wires to the switch.
7. If the alarm is activated, replace the trunk lid lock assembly.
8. Replace the trunk spoiler spacers with the countermeasure spacers (see Figure 3). Replace the trunk spoiler spacers even if you cannot see corrosion on the lock assembly switch.
9. Tighten the spoiler retaining nuts to 0.44-0.60 kg-m (3.18-4.34 ft-lb).
PARTS INFORMATION
CLAIMS INFORMATION
Classification:
EL98-005
Reference:
NTB98-054
Date:
June 15, 1998
Subject:
APPLIED VEHICLES:
APPLIED VINS:
JN1CA21A6WT308121
JN1CA21AXWT405211
JN1CA21D5WT531065
JN1CA21D1WT615349
JN1CA21D*WM924510
JN1CA21A*WM806675
APPLIED DATE:
SERVICE INFORMATION
SERVICE PROCEDURE
PARTS INFORMATION
CLAIMS INFORMATION
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
altome15
Aug 10, 2015 07:05 PM
