Ac
Old May 24, 2006 | 05:26 PM
valvestud's Avatar
Ac
what types of maintenance needs to be done on my ac because summer is here and it is hot as s***. anything i can do to make it cooler?
Old May 24, 2006 | 05:50 PM
JNCoRacer's Avatar
Just the tip.
Is it not cooling or just not cooling as well as you'd like?
Old May 24, 2006 | 06:06 PM
valvestud's Avatar
not cooling as well as id like.
Old May 24, 2006 | 06:47 PM
R5a7B's Avatar
same problem here, my ac is not cooling at all, i think a new compressor is needed, but would rather find out if its something else first.
Old May 24, 2006 | 06:48 PM
Conrad283's Avatar
I need a truck
Did you get the AC system checked out? Maybe it needs to be recharged?
Old May 24, 2006 | 07:34 PM
ManualMaxima's Avatar
5th Gen till she dies!
does anyone know hwo to empty out the 134 out of the system, cause i would liek to try the synthetic stuff, i dunno if regular is synthtic but there is some that is suppose to be better. gotta find the scoop on it
Old May 24, 2006 | 09:51 PM
valvestud's Avatar
what does recharging it do?
Old May 25, 2006 | 01:08 AM
99se5speed's Avatar
SHIFT_up
idk i have the same problem...my ac blows luke warm air at 65deg then when i turn on the recirculation button it's freezing. Do i need a recharge or what's up??? Sry don't mean to jack the thread, just that's it's a similar problem. Thanks.
Edit : i popped my hood and touched the line of the ac and it's so cold i burned my hand. idk what's up...
Old May 25, 2006 | 02:35 PM
fadeaway's Avatar
Go Hokies!!
Same problem, my AC hardly worked at all until a few weeks ago. Might want to have a shop check your Expansion Valve. Kinda expensive fix (not as much as compressor, though), but to me my AC is worth it. That was the problem with my AC. Now I have icey cold air.
Dan
Old May 25, 2006 | 03:09 PM
clive's Avatar
100% chingon
Same here. My a/c was working but not great. Specialist changed the expansion valve and now it's cold enough to freeze the b*lls off a brass monkey.
Old May 25, 2006 | 03:20 PM
guyfromkop's Avatar
how much did it cost to change the expansion valve?
Old May 25, 2006 | 05:07 PM
valvestud's Avatar
yea what he said.
Old May 25, 2006 | 07:00 PM
valvestud's Avatar
its not my fan speed or strength that the air blows, just that it takes a really long time to cool down the car.
Old May 27, 2006 | 11:58 AM
Jr25's Avatar
Where is the expansion valve? How much was it to get it fixed btw??
Old May 30, 2006 | 07:59 PM
BlackMazi's Avatar
i got quoted $400 to replace expansion valve
Old May 31, 2006 | 09:17 AM
itsdaveonline's Avatar
You just need to recharge your a/c, it should cost no more than 20$ and can easily be done by yourself.
Old May 31, 2006 | 01:25 PM
AceTKK's Avatar
I'm having A/C issues too. The fan blows/circulates air just fine but when I turn on the A/C I just get a loud hissing noise and no cold air. Does this sound familiar to anybody? I'm sure it's going to be expensive...
Old May 31, 2006 | 01:26 PM
clive's Avatar
100% chingon
The expansion valve... hmm, hard to say, because he first 'fixed' a couple of things that didn't need fixing. I think the job cost $150 incl. recharge. But this is Mexico, so you'd probably have to multiply by 100 in the US, where all AC techs have a special diploma signed by Gard.
Old May 31, 2006 | 01:30 PM
spiff56747's Avatar
I just paid $1300 total to replace my AC compressor, drier/receiver, and condenser The mechanic said the latter 2 were damaged in an accident I had 3 years ago, but everything was working fine until the A/C compressor blew up a couple of months ago.. Me = pwnt
Old May 31, 2006 | 02:43 PM
devilz05's Avatar
Shift_3.0
Nothing is wrong, the A/C cant get cold when you have hot air coming in from the outside...
Old May 31, 2006 | 03:05 PM
f550maranello2's Avatar
Ac is a closed loop system.. if it doesnt leak it should be cold always
If ur ac needs charging it has a leak somewhere.... dont just refill it because it will just leak out again...
You can try to charge it urself but that doent usually work.. take it in and let them tell you whats wrong with it
Old May 31, 2006 | 11:54 PM
99se5speed's Avatar
SHIFT_up
lol what? i don't think my problem is normal at all.
Old Jun 1, 2006 | 06:01 AM
BigLou93SE's Avatar
My AC is one thing I never wanted to have to spend money on...and now mine doesn't blow any cold air...sucks bad.
Old Jun 1, 2006 | 07:52 AM
Tryonetic's Avatar
I feel your pain... I just got the ac compressor and evaporator replaced...total about $1200 parts plus labor
Old Jun 1, 2006 | 11:36 AM
guyfromkop's Avatar
i just spent $20 and refilled my ac, blows so cold now it will freeze your nipples off
Old Jun 1, 2006 | 02:20 PM
udienow's Avatar
I have the same problem with my ac. Its cool... but its not cold. It bearly keeps the car cool on a hot day being constantly blasted at 65 deg. I hope to just refill the ac and hope that fixes it.
Old Jun 3, 2006 | 06:26 AM
thinfine's Avatar
About 6 years ago, my Maxima's A/C would not cool at all. The car was still under warranty, so I took it to the dealer and they were unable to find any leaks(use a blacklight for detection). They claimed that they re-charged the A/C. It cooled for about two - three weeks then stopped cooling. I took to a little mom & pop place, where they recharged the coolant. I have not had ANY problems since then. Which leads me to ask, how could 6 years go by without any problems if there was a leak?
Old Jun 3, 2006 | 06:48 AM
pmohr's Avatar
No more Maximas...
Some leakage is 'normal', though - up to 1/2lb per year.
