HORRIBLE SCREECHING noise at startup
Old May 24, 2006 | 08:30 PM
iregula's Avatar
I have this horrible screeching noise at startup..mostly on colder weather. when i press on the accelerator,it makes the noise louder and screechier but after it 'warms up' the sound dissapears. when i go somewhere and come back after a while the noise comes back on start up. what is it?
Old May 24, 2006 | 08:40 PM
Nealoc187's Avatar
SLOW
wow... it's one of your belts. tighten or replace.
Old May 24, 2006 | 08:49 PM
Supermax95's Avatar
+1 check your belts
Old May 24, 2006 | 08:56 PM
iregula's Avatar
which belts?
Old May 24, 2006 | 09:01 PM
Megan's Avatar
Same thing happened to me after my car went in for something to get fixed. Just take it to the mechanic and let them hear the noise or describe it. This is so commonplace, I've heard many a car in my lifetime with that exact same noise. BTW, when I took it in all the guy did was pop the hood and adjust something with a wrench. It took about 20 seconds. As long as the belt doesn't need to be actually replaced this should not be expensive nor time consuming. I'd be suspicious of anyone who said it was.
Old May 24, 2006 | 09:27 PM
Luigi38's Avatar
I had the same problem a while ago.
1. If you have the stock alternator, the bearing is known to make madd noise and only in startup, check it.
2. Your belts, the ac and accs belts.
3.HOpe is not ur case, the timming chain.
Good luck.
Old May 24, 2006 | 10:12 PM
90stanza's Avatar
its just your belts do as NEALoc187 said.
Old May 24, 2006 | 11:16 PM
FantasyGod's Avatar
belt dressing for quick fix.
Old May 25, 2006 | 05:01 AM
Rick James's Avatar
Your starter might need to be re-greased!
Old May 25, 2006 | 05:22 AM
runyun972's Avatar
Why would it be the timing chain?
Timing chains dont make a "screeching" sound then go away when it warms up.
Chains rattle - not screech
Old May 25, 2006 | 05:28 AM
reggaeboyz's Avatar
mine does the samething i been trying to figure out whats the problem i replaced both belts and it still does that..
Old May 25, 2006 | 11:11 AM
Fr33way™'s Avatar
Wild for Width
All that will do is slosh around brown gunk that will forever be sprayed all around the pulley/axle/oilpan/timing chain area. It won't tighten the belt.
AND tightening the belt is free as well as having none of those negatives.
Old May 25, 2006 | 11:12 AM
Fr33way™'s Avatar
Wild for Width
They still could be loose or your tensioner could be broken.
Old May 25, 2006 | 11:13 AM
Fr33way™'s Avatar
Wild for Width
He says the noise continues with revving and fades as it warms up. Not starter.
Old May 25, 2006 | 11:30 AM
Rick James's Avatar
I know, my car does the same thing and all the belts have been replaced and tighened.
http://www.motorvate.ca/mvp.php/516
Old May 25, 2006 | 12:12 PM
Dexter's Avatar
if you run a bad tensioner for a while oil will cease to get to the timing chain, causing it to run without lubrication which in turn causes it to screech, at this point is when your VERY CLOSE to F*CKING UP your engine
Old May 25, 2006 | 12:28 PM
runyun972's Avatar
ok, i thought the tensioner only put tension on the chain
i didn't know it was the sole provider of oil to the chain
Old May 25, 2006 | 01:21 PM
ManualMaxima's Avatar
5th Gen till she dies!
this was my case.......i tried to regrease and could not get the ***** back together...........i went and bought a life time warrenty one, and since then no problem
EDIT: if it continues it is probely the belt......
Old May 25, 2006 | 07:18 PM
Fr33way™'s Avatar
Wild for Width
One start with the hood up and someone, better yet you standing there. They are on opposite sides of the engine bay so it will be obvious.
If turning the steering wheel just after startup makes it worse it is your PS belt, otherwise it is the accessory belt slipping while cold.
Old May 25, 2006 | 07:20 PM
Fr33way™'s Avatar
Wild for Width
Good luck.
The AC belt IS the accesory belt. AC/ALT/idler pulley
The other belt is the power steering pump.
Old May 25, 2006 | 07:27 PM
hellfyre's Avatar
Try turning on your car with the AC on i.e. turn your car off without turning the ac off prior. Come back in the morning, start the car and the AC will come on immediately and the sound will be even worse. Then thats the AC belt.
If you have auto climate control, turn the car on and put the defrost ON, and that should make a louder noise than normal if it is the AC.
The starter makes a different kind of sound. It sounds like a motor spinning out of control and then stopping a few seconds after the car starts.
If its not, then its got to be those pulleys/tensioners or alternator
Old May 30, 2006 | 12:24 PM
salena1973's Avatar
I have had that screeching noise for some time I replaced the belt and it was fine for months then it started again so I replaced the tenisoner pulley but that wasn't the problem either I thought I needed to replace the other belt when I got under there to do it the whole entire belt is covered in grease it looks like wheel bearing grease but I have no idea where it came from nothing appears to be leaking. Anybody have any suggestions?
Old May 30, 2006 | 05:36 PM
Nealoc187's Avatar
SLOW
maybe your inner cv boot is cracked and it is flinging grease up there on the belts?
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
