more evap problems!!! HELP!
Old May 25, 2006 | 07:35 PM
appleman's Avatar
so after i got the codes for evap and evap flow/control you guys told me to blow out that white valve in the rear. I did so and black charcoal came out. and a good amount. so i thought i was good. i drove it for a while no cel i was feeling really good. now after 50-60 miles the light comes back. same two codes. i reset the ecu just to make sure and sure enough 60 miles later the same codes. Before this when i first recieved the codes and i would reset the ecu it would take 5 or less minutes for the codes to appear. no it seems like by cleaning out that valve the only thing it did was lengthen the time it takes to throw the same damn codes. anyone have any ideas.
the codes are 01 11 evap control/ flow and i think the other was 07 05 but dont quote me on the second one. either way they have been the same two codes the entire time
thanks guys, i really gotta fix this soon as inspection is due.
Old May 26, 2006 | 09:34 AM
appleman's Avatar
please anyone!
Old May 26, 2006 | 10:18 AM
9maxima5's Avatar
I had the Evap code also and i replaced the valve and the canister and i am about 200 miles and still no codes.
Old May 26, 2006 | 06:33 PM
appleman's Avatar
so you replaced the white valve with the 4 nipples right?
Old May 26, 2006 | 06:45 PM
hollaatchaboi's Avatar
I have the same problem. I took it to maximum tuning and jeff told me to replace that valve. I did this, however, the code still comes up. I was told by someone, when you change the valve, you have to change the canister also. Before I go buying a bunch of parts, how do i make sure what it is. This code is called the jackpot code because it can be one of many things. Whats the best thing to take care of this?
Old May 26, 2006 | 06:52 PM
D-Bo's Avatar
Droppin logs
I'm working through his now. If you had charcoal pouring out of your system like I did a new canister will be needed and likely the valve too. When the element in side has degraded to the point where it fills the rest of the EVAP system it is in need of replacement.
Old May 26, 2006 | 06:55 PM
appleman's Avatar
so i should replace that white valve with the 4 nipples and the long black square canister. what about that black vent valve near the canister?
does anyone have part numbers?
Old May 28, 2006 | 10:01 AM
Pieps's Avatar
With the cleaning of the white piece like appleman did, how do you get that out. Do you just undo the hoses on it and take it out, or do you have to do anything before that like pulling a fuse to release pressure??? Thanks
Old May 28, 2006 | 10:05 AM
MDeezy's Avatar
I am throwing an evap code also, I'm confident (and hoping) the problem can be resolved with cleaning out various parts.
Working on the car tommorow and will keep you guys updated and with pics.
Old May 28, 2006 | 08:11 PM
Pieps's Avatar
So i took the white piece off and blew that out with air, no carbon came out. Put it all back together hoping it would help, but to no avail. Any other possible solutions that you can think of?
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
homeofbacon
Sep 23, 2015 07:17 PM
dcam0326
Sep 7, 2015 07:26 AM
