PLEASE HELP!! (Stillen Intake)
Old Jun 18, 2001 | 11:27 AM
Nick97SE's Avatar
Guys...
I bought a used intake from my neighbor. He had it on his '99 Max SE. I just put it on my '97 Max SE. Everything sounded and looked great except after I installed it, I realized that there was a hole drilled in the end under the word "STILLEN". There is an unusual sucking noise coming from this hole (which is obviously the air going in), but is the hole supposed to be there? I haven't paid him for it yet, and if it's not supposed to be there, I'll give it back and say I don't want it. I've attached a picture of the intake. Please tell me if the hole is supposed to be there. I don't think it is because it's unfiltered air going in...and I need to know because I have to take my car somewhere...and I'll put the stock airbox back in if I need to! Thanks!!
-Nick
Old Jun 18, 2001 | 11:40 AM
Nick97SE's Avatar
Sorry guys...the attach feature didn't work!
Here's the pic:
Please Help!!
-Nick
Old Jun 18, 2001 | 12:22 PM
ereet's Avatar
Heh,
I don't have a stillen intake, but my cone is designed in a M shape, (ie, /\/\).. It sucks air through the sides, and through the top. I'd venture to say the stillen one is the same. If someone with one doesn't verify this, just make sure there's part of a filter in the hole..
Sucking noises are normal with an intake, you'll get used to it.
Old Jun 18, 2001 | 12:36 PM
maxi-milliyon's Avatar
Intake
That hole is for the air tempature sensor.Chances are you took out your old factory box. On the botttom half of the box will have the A.T.S.. you have to pull this out and put
it in the stillen hole. If you don't you may get a check engine code. Also you may get dirt suck into your engine so cover up the hole until you put the sensor in.
Old Jun 18, 2001 | 01:15 PM
jay_x's Avatar
that is actually the version of the intake for 95/96. in the 97-99 the sensor is mounted somewhere else. just plug the hole with a gromet or large screw.
Old Jun 18, 2001 | 02:11 PM
DFWmax's Avatar
yeah, the 99s dont have a sensor to plug up the hole, but the previous models did (dont know which years). if you dont have a sensor to fit into this hole, you should just plug it up with something. maybe a piece of plastic, and magic duct tape...
dfwmax
Old Jun 18, 2001 | 02:58 PM
Nick97SE's Avatar
Do you think I should consider selling this to a member on the forum with a 95-96 and buy the correct one for my car? That is always an option.
-Nick
Old Jun 18, 2001 | 03:31 PM
ereet's Avatar
Plugging it with a screw is the route I'd go .. If you're really picky about your cars condition, and don't want any "ghetto" style mods on it, sell & rebuy .. But I'd just plug up the hole with something.
Old Jun 18, 2001 | 04:11 PM
GTRBlkMax97's Avatar
MaxedOut97SE ordered directly from stillen and has that hole, just plug the ATS in it
Old Jun 18, 2001 | 04:15 PM
Stillnmax's Avatar
nick aim me bro ...
Old Jun 18, 2001 | 05:41 PM
SC99MaxSELmtd's Avatar
Stillen Intake
That intake will work for the 99, I have it. The Ambient Temperature Control is under the stock intake. You have to play w/ the wiring to get it to reach the hole in the Stillen intake, but it will. If you run the car w/o that hole being covered, your check engine light will come on and you will have to take it to the shop. When you take off the stock box, there are two holes - one for the MAS intake to the engine and the other for air coming in from outside through the intake duct. Reach into the bottom hole of the intake duct and feel on the right side. You can feel the ATC. You will need to take the rubber seal out as well. Plug them both into the hole on the Stillen intake and you are ready to go.
Old Jun 18, 2001 | 06:26 PM
Nick97SE's Avatar
Well, after I put the intake in...I made a BIG mistake and ran it. This was before I realized the hole was there. Well, I always knew it was there...this was before I realized it shouldn't be there!! Anyways, I ran the car for a minute or two to listen to it. Now my check engine light is on!! I took out the STILLEN Intake and put the stock airbox back in for now. I also just took the car to a few errands (with the stock airbox) and the check engine light remained on the whole time.
SC99MaxSELmtd: I have a '97. Does my car have this ATC? If it does, I'll go out and hook it up the right way.
What I really want to know is...what am I supposed to do about my check engine light now?
Thanks for everyones help,
-Nick
Old Jun 18, 2001 | 07:39 PM
Ravq's Avatar
-Nick
Just reset the ECU and hope it stays off. Just follow the instructions under the How2 on Cheston's site:
http://www.maximadriver.com/
Old Jun 18, 2001 | 09:28 PM
-Nick
If your 97 has automatic temp. control for air/heat, it should have the Ambient temp control sensor. This sensor takes the air coming in through the intake to judge the temp. outside. I think it is on the 97 as well if you have auto. temp. climate control.
Old Jun 19, 2001 | 07:45 AM
Nick97SE's Avatar
I have the Auto Temp. Control.
I'd like to install the intake this way...I might try it.
First I gotta figure out what's up with my check engine light.
-Nick
Old Jun 19, 2001 | 08:04 AM
Nick97SE's Avatar
Ok...
I got two error codes:
0102 - Mass Air Flow Sensor
0304 - Knock Sensor
Where do I go from here?
Thanks,
-Nick
Old Jun 19, 2001 | 08:18 AM
fast97maxse's Avatar
I put the Stillen intake on my 97 SE.
The sensor should be pretty obvious when you take off the stock box.
The Stillen instructions were a bit limited. [as in, they suck]
They said to loosen the wiring "loom" or whatever it is
to get the length in the wire.
I couldn't do that, so I just spliced in about 6 extra inches
of wire.
However, when I went to the LSP meet
I saw lots of hiflow filters [non-stillen]
with a solid piece of metal and no place for the sensor.
I was wondering about that.
Wasn't thinking about model year though.
Old Jun 19, 2001 | 08:22 AM
Nick97SE's Avatar
Well, I bought the intake used and didn't get any instructions with it. I e-mailed STILLEN asking if they could send me some...but they didn't. So I just installed it not even knowing about the sensor.
I also didn't get the cleaning kit for it, which I'm trying to find one.
-Nick
Old Jun 19, 2001 | 08:35 AM
-Nick
Do you have/have access to a fax machine?
I can bring in the instructions tomorrow and send em to you.
If not, I can scan them and attach a jpeg
but faxing is easier...
Also, where are you?
If you live in Cali, you need to have a sticker [comes w/ the Stillen filter]
that certifies the filter for emissions or something like that.
If you do live in Cali, I could send you the one that came with mine.
Old Jun 19, 2001 | 08:39 AM
Nick97SE's Avatar
I live in NJ. Not sure if I need the sticker. Where do you put it anyways?
Also, I think I have a fax machine built into my computer. I'd have to ask my dad to be sure about that though. I'd really appreciate it if you could fax them to me. This forum has some really good members!
-Nick
Old Jun 19, 2001 | 08:49 AM
-Nick
I forget where they say to put the sticker.
I think under the hood or right on the filter
but it doesn't matter in NJ, just Cali I think.
And it isn't a "nice" sticker anyway, just informational.
So, check w/ your computer tech guy and lemme know...
Old Jun 19, 2001 | 08:57 AM
Nick97SE's Avatar
My computer tech guy is my dad...and he's at work. I'll ask him tonight and I'll let you know.
You want me to e-mail you?
-Nick
I figured out the problem with my check engine light. I turned the car off and back on and did the procedure again and got error 0505, which means "All Clear" according to bill99gxe's post.
I reset the ECU and started the car and the light was off. I'm happy now. All I want to do now is install my intake the right way!!
-Nick
Old Jun 19, 2001 | 09:09 AM
-Nick
I know, just jokin'
sure - email if you want:
jmlee@modemmedia.com
Old Jun 19, 2001 | 09:45 AM
Nick97SE's Avatar
fast97maxse: Do you have AIM?
If so, AIM me @ NRB1225.
-Nick
Old Jun 19, 2001 | 10:22 AM
-Nick
sorry, no.
My parents always said I was aimless...
Old Jun 19, 2001 | 10:37 AM
Nick97SE's Avatar
I'm gonna e-mail you then. Check your mail in a few minutes.
-Nick
Old Jun 19, 2001 | 11:19 AM
96max's Avatar
Just read that you needed the instructions, so here they are.
http://www.geocities.com/cellphone_1...nHighFlow1.jpg
http://www.geocities.com/cellphone_1...nHighFlow2.jpg
http://www.geocities.com/cellphone_1...nHighFlow3.jpg
Old Jun 19, 2001 | 11:24 AM
96max's Avatar
Just a note, yahoo i guess doesn't allow links to anything on their server, so if u click on the hyperlink, it will not work, however, if you are using IE, you can right click the link and go to copy shortcut, then paste it into a new window, it will work fine.
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
maxima297
Sep 30, 2015 03:32 PM
MichMaxFan
Sep 30, 2015 09:18 AM
