Car won't go above 2000 RPM
Old May 28, 2006 | 07:26 PM
ancientwiseone's Avatar
Hi guys, today I was driving my max and then all of a sudden I couldn't get above 2000 rpm. Once I gun it, it will stop and jerk at 2000rpm. Can anyone tell me whats wrong? Thanks alot.
Old May 28, 2006 | 07:29 PM
tikiboom's Avatar
I need an intervention
check your MAF sensorconnection
when its not hooked up it doesnt rev past 2000 and sputters like like its gonna die.
If its plugged in, unplug it, check for dirt/grime whatever and plug it back in.
If that doesnt work get a new MAFS
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Sounds like your MAF could be bad. If you have any friends who have maximas you could swap MAfs to see if that really is it. You can find a used maf on here or ebay for around $60.
Old May 28, 2006 | 08:31 PM
Dexter's Avatar
it also does that if your radiator hose is disconected...
Old May 28, 2006 | 08:42 PM
valvestud's Avatar
it is def the MAF. Its like a low RPM rev limiter lol.
Old May 29, 2006 | 08:53 AM
Black_Max_SE's Avatar
I was following a cement truck on the interstate and a chunk hit the bottom of the radiator. Before I got to a gas station the car started doing the same thing, only ran below 2k. Temp was fine, just completely out of coolant since there was a hole in the bottom of the radiator.
Wouldn't hurt to check your coolant level.
Old Jun 3, 2006 | 06:46 AM
thinfine's Avatar
Reliable place to purchase
I just took my Maxima to the dealer yesterday due to problems with my '96 cutting off when I am stopped or when slowing down. I noticed that the RPM drops to 0. The dealer indicated that my Mass Airflow sensor and Knock sensor is bad. The dealer charges $610 to replace the Mass Airflow Sensor and $760 to replace the knock sensor. I just checked ebay for a Mass Airflow Sensor for a Maxima, but I didn't see any. Any suggestions for reputable supplier(s)?
Old Jun 3, 2006 | 06:54 AM
MaximaInCT203's Avatar
schemes on chicks in his max.
i have a spare Mass Air Flow Sensor for sale if you wanna buy it from me.
let me know
Old Aug 6, 2014 | 10:30 PM
bootsxVQ30's Avatar
Tps!!!
If it is not your MAF
CHECK YOUR TPS!! I had the same problem. So I went and got a trottle body with the throttle positioning sensor already set off of an old 4th generation maxima swapped it with my old one and i no longer have that problem.
Old Aug 7, 2014 | 11:18 AM
Chad_m's Avatar
Wow. Excellent job raising this thread from the dead. Did you not see that it is an 8 year old thread? Check the dates before you post.
Old Aug 7, 2014 | 11:23 AM
Fakie J Farkerton's Avatar
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
Maxboy23
Aug 11, 2015 11:59 AM
