Testing Coilpack w/ Multi-Meter
There are 3 connections:
Pin 1 - red wire on every coil pack
Pin 2 - black wire on every coil pack
Pin 3 - different color on each coil pack (trigger from ECU)
measuring between Pin 1 and Pin 2 connections:
reads 1.6 kilohms (polarity doesn't matter).
measuring between the Pin 2 and Pin 3 connections:
reads 7.1 megaohms (polarity doesn't matter).
measuring between Pin 3 and Pin 1 connections:
positive lead on Pin 1 reads open (or infinity)
positive lead on Pin 3 reads 7.7 megaohms
Testing doesnt always work though, it can test fine and not work. The only 100% accurate way to test it is to, with the car running, unplug individual CP's and see if the idle hiccups. If it does then that CP is good but if nothing changes then its bad. Easier I think too
tarun900
19
12-20-2021 06:57 PM
knight_yyz
11-01-2015 01:34 PM
DC_Juggernaut
09-28-2015 04:07 PM
