center console heating up .
Old May 29, 2006 | 10:51 PM
ukraini9mofo's Avatar
For some reason my center console heats up whenever I shift and drive a little more aggresively, on driver side its fine, however one day, my friend that was sitting in passenger seat notcied substaintial heat coming from somewhere. It is comin from my center console and also when I reached below the shift **** to feel the lever, it was hot ( not 2 hot but pretty warm). Any ideas on this ?
Old May 29, 2006 | 10:54 PM
ManualMaxima's Avatar
5th Gen till she dies!
did you take the heat sheilds off of you car above the exhust?
Old May 29, 2006 | 10:58 PM
nope did not touch anything, I did have a 5spd swap done 2 months ago by tilley but i doubt, it had anythin to do with this.
Old May 30, 2006 | 09:37 AM
any ideas ?
Old May 30, 2006 | 09:56 AM
greengrass215's Avatar
cat. converter getting hot. maybe your motor running to rich, making it every hot in the converter.
Old May 30, 2006 | 10:16 AM
aznsap's Avatar
you do realize that the bulge in the interior compartment where your center console sits atop of is where the exhaust runs through below the car right? and the base of your shifter and shift linkage is directly above the cat converter and distal end of the Ypipe (only inches away).
i don't know what can explain the heat you're getting though, maybe you have an exhaust leak there? or what somebody said earlier about the cat. getting hot.
Old May 30, 2006 | 01:14 PM
RA030726's Avatar
I'm nutty for Nissans
Also the heater ducts are down there too. They go under the seats to heat the rear. Maybe you have the heat on and its slowly comming out.
Old May 30, 2006 | 02:43 PM
HM_Motorsports's Avatar
You said you had a 5spd conversion done. There's a shield that's bolted to the floor that seals around the shifter inside the consol. It's pretty thick rubber material. if you didn't grab that part and install one then heat could be rising up from the exhaust through that hole. It's worth a check. You can see it by just popping off the center consol trim around the shifter. Look at where the shifter goes through the floor. If you can see pavement, then it's not there.
tarun900
19
Dec 20, 2021 06:57 PM
gigabyte
Jan 6, 2017 06:05 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
