Stereo does not work - Fuses?
Old May 30, 2006 | 11:00 PM
VQ30DE's Avatar
I turned on my car this morning and the speakers did not work for any option of the stereo. Tape, Radio, CD etc. Could this be a fuse problem (if so please indicate what fuse slot and voltage because my fuse box list is MIA 1995 maxima SE), and if it is not a fuse problem please give me any course of action I could take to determining the problem and solution to it.
thanks in advance!!
- luke
Old May 31, 2006 | 06:32 AM
MIXXMAX's Avatar
Fader position, speakers blown??? You need to give us more information. Is it a stock radio, aftermarket? More information needed and maybe we can help you.
Old May 31, 2006 | 11:07 AM
VQ30DE's Avatar
I already fooled with the fader and balance, they are fine. It is a stock Bose radio with stock speakers and stock head unit. I haven't ruled out that the speakers are not blown.
Old May 31, 2006 | 11:11 AM
MIXXMAX's Avatar
It could be the radio itself. The crappy Bose systems in Nissans are terrible and usually don't last that long. That is why most people just remove it and upgrade to a better stereo. In fact, when I got my car, the Bose only stayed in the car about a week at the most before I removed it.
Old May 31, 2006 | 11:18 AM
Xyquine's Avatar
Its the Rear Speakers. I had the same problem. Unplug them then replace the 15 Watt Fuse and it shoudl work fine. You just need to replace them. if its not the rears its the fronts but the rears are easier to diganose.
Old May 31, 2006 | 04:32 PM
VQ30DE's Avatar
Would you be able to tell me what fuse slot they are in, my panel is missing so i do not have the picture of the fuse box.
Also im pretty nooby with cars, would i unplug the rear speakers from the trunk?
Old Jun 1, 2006 | 01:20 PM
VQ30DE's Avatar
PLEASE!
help me out
Old Jun 1, 2006 | 01:31 PM
Digitized's Avatar
make sure it isn't a wire shorting out the speakers ( I had this issue on my 94 accord)...
because of 1 speaker shorting out, all 4 would stop emitting sound.. .make sure you don't have loose wires near the speakers...
Old Jun 1, 2006 | 01:39 PM
CRiME's Avatar
oem ftw!
look in the center row, i believe it's either the 3rd or 4th fuse down from the top. One is labeled "audio" and one is labeled "bose". check them both. i can't remember exactly which one, but it's one of the two ( i think it's the 'audio' fuse that protects the speakers). if you replace the fuse and it blows again, there's something wrong with one of your amps and you need to disconnect them until you find the faulty one. if the fuse blows again, begin checking the rear amps first.
trasmadean
Feb 1, 2017 08:20 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Derrick2k2SE
Aug 12, 2015 06:47 PM
kenc15
Aug 5, 2015 08:29 AM
