alignment after ball joint replacement
Old Jun 1, 2006 | 05:50 PM
showoff's Avatar
Do i need an alignment after i replace a ball joint??
Also, how soon after...will it be messed to where I can't drive (ie. after i replaced struts) or will it be drivable for a day or 2??
Old Jun 1, 2006 | 05:56 PM
nismology's Avatar
There will be many here that will impulsively say that you absolutely need an alignment but the truth is that you don't. Caster is not adjustable, removing the strut to steering knockle bolts and nuts and reinstalling them changes the camber a fraction of a degree at most (not adjustable anyway), and the only thing that is adjustable, the toe, won't be changed as long as you don't touch the lock nut on the tie-rod.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
