cant get ECU out?
cant get ECU out?
hey guys i just got TS ecu, and i cant seem to figure out how to take out my stock one..there are so many wires and stuff tied to it, that they are in the way of the boots. is there a howto anyone has on how to take it out?..some pics would be good too
thanks
thanks
I think i read somewhere on here that its easier to take out the ecu with the bracket attached to it instead of seperating it from the bracket. Donating and searching would help you a ton.
when I did was take out the four screws holding it in, I used a short screwdriver where possible and when I couldn't use that, I just used some needle nose pliyers to turn the screws out from the sides, it dings them up a little bit but not too bad.
Good luck, it a pain in the butt to get that thing out of there
Originally Posted by 95GLEMAXX
haha its just chillin on the floormat now, cant leave it like that forever tho...thanks again guys
remove the bolts, the screws are what holds the backet to the ecu. Just remove those bolts, then the ecu with the backet will come out. Remove the 10mm bolt that holds the ecu to the wires and then swap.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
