misfiring
Old Jun 7, 2006 | 02:26 PM
Mr Willis's Avatar
misfiring
What causes misfiring because my car is doing it a lot. I currently have KS code and front right 02 sensor code. It only happens at really low rpm's when i'm pulling away from a stop sign or when the light turns green.
Just replaced sparkplugs and it didn't really help. I have an exhaust leak. could that be it? Any suggestions would be appreciated.
I don't want to put any real money into this car. Thanks
Old Jun 7, 2006 | 02:28 PM
JwaxMax99's Avatar
Coils......And, you should be getting a misfire code, if you are actually misfiring.
Old Jun 7, 2006 | 03:59 PM
motocross416's Avatar
first thing is fix your codes and then go from there.
If you don't want to put money into the car, sell it and buy a car that has a warranty. You'll just end up with more problems down the road if you don't keep up on maintence
Old Jun 7, 2006 | 08:07 PM
f550maranello2's Avatar
bro check the fuel injectors.. i had the same problem when i put new ones in.. they didnt come with the plastic pintle cap that goes on top of the injectors.. they gave me nasty missfires.. also check the o rings they can leak..
Old Jun 7, 2006 | 08:21 PM
my97maxi's Avatar
i bet money its either the KS or some kind of bad connection ( get your codes fix asap)
this MAY help:
http://forums.maxima.org/showthread.php?t=473170
Old Jun 8, 2006 | 05:57 AM
The knock sensor will not cause the car to run like that, it will just be down on power with a dead knock sensor. Fix the exhaust and O2 and then go from there if there are still problems
Old Jun 9, 2006 | 12:05 PM
Mr Willis's Avatar
Well, merlins said i have a leaking intake manifold (whatever that is). Could that be causing this horrible, popping, hesitation?
Old Jun 9, 2006 | 02:05 PM
radar912's Avatar
I had the same thing, #2 cylinder coil pack, my ECU indicated it tho, so easy fix, clear the OS code 1st, KS is probably due to the misfire, had it with mine as well.
Old Jun 9, 2006 | 10:10 PM
smotz's Avatar
Brain phuck
Dude its probably your coil pack things. at night park your car somewhere that has NO light.. no lamps or anything you want it really dark. Let your car idle and look at the spark plug connectors/coil packs and see if you see sparks. If you do its the coil packs for sure.
jmlee44
Oct 2, 2022 02:13 PM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
ballerchris510
Sep 11, 2015 05:29 PM
