Engine Vibrations/Resonance
Old Jun 11, 2006 | 07:34 PM
LTU_max's Avatar
Ever since the seafoam my engine started making these sounds. Sounds like some vibrating, and usually can hear it between idle and 2k rpms. I recently had an oil change after the seafoam, but I notice the sound even more now. Any ideas on what this can be?
http://smg.photobucket.com/albums/v6...=Resonance.flv
Old Jun 11, 2006 | 07:38 PM
llama's Avatar
dam ur **** sounds really ****ed up, i dont know a lot about cars, sorry
Old Jun 11, 2006 | 07:42 PM
Pieps's Avatar
Then why post?
Old Jun 11, 2006 | 07:54 PM
ti2tmax's Avatar
Has his VINs memorized
Wow, I have a vibration due to not surfacing my new flywheel when I installed it with my new clutch it occurs during those RPMs that you are getting that sound/vibration. it's not something spinning in contact with something?
Old Jun 11, 2006 | 08:02 PM
LTU_max's Avatar
I have no idea. That is possible, since I haven't touched the clutch/flywheel since I bought the car (only been 3k miles) Here's another detail: The video you see there is when I put MORE seafoam in through the brake booster hose, about 1/2 can. Before the sound was much less noticable, but when I put more seafoam after a few weeks the sound got worse. That's the video you see.
Old Jun 11, 2006 | 08:07 PM
ti2tmax's Avatar
hmm, I once put half a can of seafoam in mine, and I couln't see 15 feet from me there was so much smoke. But no funny sounds like you have... Also afterwards my engine dieseled for about 5 seconds!! I had to crank my volume WAY up to hear it, does it sound like small pebbles in a tin can in person? cause at the back of the intake manifold on mine I have a slight sound like that just before my idle acts up. It sounds like your idle is stable. Was the car at operating temp when the video was shot?
Old Jun 11, 2006 | 08:22 PM
f550maranello2's Avatar
thats why i dont really like using seafoam directly like that... i dont really see any difference in performance either
Old Jun 11, 2006 | 08:43 PM
ti2tmax's Avatar
I notice a little bit the first time, but nothing in the past two. I did the third in oil third injected brake booster and third in the gas tank most times. That noise is scarry!
Old Jun 11, 2006 | 08:54 PM
nismology's Avatar
Seafoam is useless...
Old Jun 12, 2006 | 08:55 AM
LTU_max's Avatar
It's really starting to bug me. I don't know if my engine is going to fall apart because of that noise, since it can gradually get worse. Since it's probably internal, maybe some sort of cleaner/lubricant should do the trick? Something better than seafoam? What I don't understand is what could've the seafoam done to the engine to make such a noise?
shilov
Feb 19, 2024 09:40 PM
James92SE
142
Jan 2, 2024 09:23 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
