new serpentine belt smell
Old Jun 14, 2006 | 08:51 PM
Maximeltman's Avatar
ok after i installed my new high output alternator and changed to a belt, i notice a bit of a burning scent under the hood. is this the smell of the new belt just breaking in??
Old Jun 15, 2006 | 01:19 PM
Motorhead52's Avatar
No, something is burning up.. You should check to see if the belt gets really hot. If it is, it might be too tight. If it isnt, then its not the belt, and you have a wire somewhere that is melting.
Old Jun 15, 2006 | 02:11 PM
hmm ok, i loosened it a bit thanks
Old Jun 15, 2006 | 02:17 PM
whitegold's Avatar
Did that fix the problem?
Old Jun 16, 2006 | 06:44 AM
sorta..but it still smells just not as bad. I drive around with the volume cranked and then without it on at all, then see if I can notice a difference in the smells. I think it is the belt.
Old Jun 16, 2006 | 01:57 PM
clive's Avatar
100% chingon
The volume cranked? What, do you have a kilowatt audio? Instead, turn on the headlights, the heated rear window, the blower fan to maximum, and play with the power seat/sunroof/ any other motorised item. oh, and wash the windows and use the wipers as well. That'll test the alternator output.
High output alts are all very well, but why did you install one, are you running extra amperage through the original harness? If so, you should have bought a high output wiring harness as well
05' MaximaMan
Oct 8, 2017 06:36 PM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
RWCreative
Sep 21, 2015 11:01 AM
