List of common mechanical failures in the 4th Gen
#41
Originally Posted by Innocent_Maxima
What can be done about the noisy strut mounts and all? I am hearing lots of noise from the back area and I really have no idea what is causing it all. I took out my rear coilovers thinking it was them (there are springs in the back at the moment).
Then in the past two days I had $5gs worth of maintainance done on the car, part of which included replacing the bumpstops/dustboots as well as the upper strut mounts. After I got the car back today the car still makes the noises in the back and it drives me crazy.
If anyone can please help me with this issue and to see what can be done to make it quiet again it would be greatly appreciated. Thanks
#42
High Pitched sound coming from engine when at a stop
Back windows falling down due to window regulator and a cheap plastic piece nissan puts in there that breaks eventually.
Engine Coolant Temperature Sensor (ECTS)
Saggy trunk floor (just got finished replacing mine and its ALOT better)
Knock Sensor of course
#43
other then my tranny bearing in my 5spd nothing other then normal maintenece stuff has been replaced. original clutch, tranny (about to go though), engine(compression is excellent). The car has 182,000 miles which is around 294,000kms. In my auto it needed a full engine rebuild because the previous owner never maintained the car and the detonation and everything else that constantly happened ended up blowing a headgasket. the timing cover was leaking, took nissan like 5 weeks to fix that after replacing the oil pan.
Differential carrier bearing (5spd)
****ty paint, chips and gets scratches easy as hell
knock sensor
wheel hop (5spd) :P
cant really think of anything else thats gone majorly wrong in my 4th gens, there very reliable cars when maintained properly and will last for along time.
knock sensor
wheel hop (5spd) :P
#44
Hi Guys, new bee here !!! This is my first post so please bare with me....
I bought my 1996 (used) when it had 70k miles on it in 1999. Just now hit 170k mark
Looking at this list of problems, I have some of them already fixed but I will report them anyways..
- knock sensor (bought it from eBay for $68 and replaced it myself)
- Bose "CD Err" (there is a local Bose Authorized Shop in Long Island, NY who fixed it for me for $150)
- EGRC (Control) Solenoid Value (pain in the b** to replace but finally did it myself. Bought it from stealership for $70)
- Start problems (had it fixed it about 2 years ago at stealership)
- Changed my struts twice so far. Recently 3 months ago. Put KYBs.
and finally got CLE with code P0130 or you can say DTC0503 which is for O2 sensor. Bank 1 Sensor 1. I was about to get it replaced but found a very helpful informaton. See below and I hope anyone who owns 1996 model will be benifited from this.
Too lazy to type... so I am copying/pasting from a doc. that I was writing.. Please don't be mad or laugh at me !!!
Front Right Heated O2 sensor
(Front Left/Right O2 sensor = Left/Right in this case refers to the left/right bank of the engine. The "Left" sensor is the one furthest to the front of the vehicle.)
OR:
O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
(Bank 1 refers to Right Bank of the engine which is on the passenger side and there is only one sensor on that side so nothing to worry about Sensor 1)
Look at the diagram at: http://www.courtesyparts.com/A32_O2-sensors.html
Also, if your car is 1996 model and you NEVER changed ANY of the O2 sensors, you might want to call your local dealer and find out about Service Campaign Bulletin 'NTB98-073a'.
While searching on Google to see if I can fix it myself, I found:
http://lyberty.com/car/Maxima_A32_do...NTB98-073a.pdf
I called both, Nissan itself and my local dealership. Both said they still honor this so I am going there in a week or two to get it replaced at NO COST for part and labor
As per above NTB they only fix the O2 sensor as per the ECU code but I am planning to talk them into replacing all three sensors along with the EVAP canister
I will post again once I deal and done with them.
![clap](https://maxima.org/forums/images/smilies/clap.gif)
OR:
![devil](https://maxima.org/forums/images/smilies/devil.gif)
#46
Originally Posted by dko
wow. that's a hell of a first post. thanks a lot dude! i'm going to call the closest stealership and see if they will honor this... they have to, right?
#48
my list
evap cansiter purge valve code is on iggy CEl bulb should burn out anytime now.
lr window reg replaced
starter has been screching for 4 years now.
ign switch replaced
odometer. took a crap at 35K replaced
knock sensor code for last 3 years.
gotta give props to factory brake pads., 11 years on the rears and 30% left.
ign switch replaced
#49
so i guess no one has changed the front control arms and shocks?? I know u did or have to soo enough.
I did on my 95 auto
-complete suspension(tokiko illumina) old leaky shocks suck
-complete exhaust with y-pipe and high flow cat(stock cat-back)
-rebuilt tranny with cooler
-O2 sensors
-axles
-my timing chain rattles quite a bit at start up and stops like 1 min later
Motor is still running real strong and kicking butt on the road
I did on my 95 auto
-O2 sensors
-axles
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
#50
#53
awesome. do you have to have the CEL for o2 sensors or will they do it even if there is no problem yet
Am gonna try to have them replace them all. There is no harm in trying if it for free. Unfortunately I am busy for next two weeks but once the job is done I will let you know how it went. This way you will get a better idea before you go to the dealer.
#54
Originally Posted by alleydawg6
darn sunroof doesn't lift up fully so when it rains, water seeps in through the seals
![ThumbsUp](https://maxima.org/forums/images/smilies/thumbsup.gif)
#57
Formeraccordman, I know what you mean.
I have had that type of noise too, the one where I am turning to go on a driveway or a strip mall or anything with a bit of a ramp from the road; and going on them on angles (which I have to because of my lowered car) the body makes a big crack or stretch noise, it is very annoying and embarassing as you say.
The other type of noise I experience is from the rear also, which is what I was mentioning originally. It is a hollow metal noise that it sounds like a metallic rattle or echo, and it happens on cracks on the road, divides of a bridge, and pretty much most uneven surfaces, it mainly happens on the rebound when the rear tires have left the bump/crack/etc. I have no idea what it is and I have driven with it for over a year now and it is driving me nuts.
I really need to solve the problem, I have taken it to the dealerships and they still havn't figured it out yet. Any help is much appreciated!
#58
#59
Actually I still have not been able to solve it yet, I am still dealing with it, it is very annoying, both noises. I don't know what direction to take myself, but my car is scheduled for an audio sensor hearing where they place sensors on parts of the car and see if they can hear where it is coming from.
My appointment is sometime in July but I hope to get it solved and find out what it is before then, it is going to be expensive to get that type of diagnosing.
I have already replaced the upper strut mounts, dust boots, bumpstops, wheel bearings and some bushings. Next thing that comes to my mind are the sway bar links, but I am not sure, I wouldn't want to keep replacing parts while paying for labour if it won't fix the problem.
What else can it be?
#61
wow, no one said odo-trip stops working, also 1 battery, 2. belts, 3. electronic starter switch, 4. 02 ,5 coolant sensor, 6. rear taillight bulbs. i could go on and on but i don't care. i love my max and will drive it until such time that i deem it unfixable anymore. the paint does chip friggin really easy too........
#62
Originally Posted by JSutter
Door hinges
Crappy paint (easily gets rock chips)
Crappy glass (pits easy)
Blower resistor
Spoiler LED blows
Spoiler pops up
Antenna wont move
KS and O2 sensors
Cam sensor/Timming cover oil leaks
Parking brake cable worn on trailing arm
Rotten/Rusty exhaust (just about every piece)
Saggy trunk floor
Dain lines plugged
Oh wait you said mechanical problems..............
Blower resistor
Spoiler LED blows
Spoiler pops up
Antenna wont move
KS and O2 sensors
Saggy trunk floor
Dain lines plugged
i wish ya the best of luck
#63
Originally Posted by PARALLEX
looks like u just lucked out or someone treated your car like **** before u got it! (lucked out was sarcasm)
#64
Anyhow I find that most fastners on my car are of VERY poor quality (ie bolts, plastic fastners, etc).
Here are other common problems with these cars:
'o2 sensors failing
'rad support rusting
'ignition coils failing
'starter seizing and eventually failing
'rear calipers seizing
'parking brake cable binding/seizing
'power steering pump leaking
'hood struts losing compression and failing
'poor paint
'front windshield prone to pitting
'headlamp bulb socket corroding
'mysterious oil burning with 5-speed cars
Even with the above faults, I still rank this car way ahead of anything else I have come across reliability wise.
'o2 sensors failing
'poor paint
#66
I've had a lot of things loosen or break...I had my exhaust break and it was resting on the metal bar below it rattling around (tied it down...the cars got over 202000 miles on it not worth fixing it) and I also had a mounting screw go loose on me...I took it in thinking it was the clutch but they just tightened the screw and the rattling stopped. Other than that everything else has been listed.
#67
Bad news.. Before going to the stealership, I called the Nissan main office once again (last time I was driving so didn't have all the info. with me)... This time they asked for my VIN #. As per my VIN, my car was not part of the recall eventhough it's '96 year model. Their explanation was: Eventhough the car was sold as '96 moder, it was actuallt built in '95 and those had no recalls. It's those car which were built in '96 and sold as '96 year model...
So I guess I have to replace it on my own.
![BangHead](https://maxima.org/forums/images/smilies/banghead.gif)
You can at least call the 1-877 # number in NTB and findout about your car though !!!!
#72
I have a 99 max with 125, 000 milees and so far have replaced
02 Sensor
1 Coil Pack
and have a slight rattle in the front driver door and a rattle in the rear left, which i dont know what it can be. Please can anyone advise on the rattle.
02 Sensor
1 Coil Pack
#73
Between me and my brother owning the car from 2000, the car had 40K, and thus far I have 160K...
5 spd bearings went out
sunroof motor broke
antenna motor broke
starter went out
alt went out
KS O2 sensors
exhaust rusted out
crappy trunk floor sag, since 01
other than thati have not had any issues with coil packs, or much else... The motor is still running strong, even though we haven't been real nice to it, its been drivin hard and I can say that this VQ is one tough motor. It still takes my 125 shot of nitrous like a champ.
sunroof motor broke
antenna motor broke
starter went out
alt went out
KS O2 sensors
exhaust rusted out
Maxima_Joe
11-25-2015 08:19 AM
FlaMark
25
08-28-2015 10:15 AM
