axle nut removal
Old Jun 18, 2006 | 12:53 PM
200kMax's Avatar
axle nut removal
damn this thing is hard. i need to remove it in order to get my control arms (i do right??)
problem is i dont have an impact gun. how would i get the axle not to turn so that i can get torque on the 36mm axle nut?
Old Jun 18, 2006 | 01:30 PM
RockfordMax's Avatar
Back from the dead
put it in reverse, get a 1/2" breaker bar or a hardcore ratchet, throw a 3-4 foot cheater bar on it, and jump.
Old Jun 18, 2006 | 01:41 PM
200kMax's Avatar
u sure that would work? i guess its worth giving it a shot. iput it in 5th and it still turns. even jammed the brake pedal w/ a club and dang thing still turned.
Old Jun 18, 2006 | 02:13 PM
f550maranello2's Avatar
dont jump on anything you might break the breaker bar (like me) and then be in real trouble.... use a blow torch.. it works everytime...lots of pb blaster..
Old Jun 18, 2006 | 02:14 PM
Kevlo911's Avatar
Kevlo for President
I broke the breaker bar too.
Old Jun 18, 2006 | 04:57 PM
dgeesaman's Avatar
Maintenance Monster
I took a sturdy bar, and put it across the wheel studs, and put the end of the bar on the top of a jackstand. That kept the wheel from rotating.
Then I took a 20" breaker bar and used my full jack handle as a cheater. Then you set it on the nut so the bar is about parallet to the floor and lift. Some heat and PB blaster in advance can help, but you simply need to get a lot of leverage to overcome the torque.
Dave
Old Jun 18, 2006 | 05:44 PM
Xmax's Avatar
Use a breaker bar that used a 1in drive, and of course use a socket to fit that one inch drive. You can get one at sears part number # 4443 in the tool section. Go to your local hardware store purchase a lead pipe that fits over the breaker bar, get one that is appox. about 2 to 3 fit long. This will help for you leverage. Use these two items and hopefully you can take off the locking nut. Its gonna take a lot of strength, but it will be a lot easier to take off than just using a little dinky 1/2in drive breaker bar.
Old Jun 18, 2006 | 05:49 PM
Back from the dead
I'll snap a pic of the rig i used. It worked on the first pull.
That with a jack handle over the end of it did the job.
Old Jun 18, 2006 | 06:12 PM
maxfanfromohio's Avatar
Shiver me timbers.
You guys are telling him how you got yours off, but you are not telling him that he doesn't need to take it off in order to replace his control arm.
Old Jun 18, 2006 | 06:15 PM
Back from the dead
Oh. I dont like to read. Control arm disconnects at the ball joint from the knuckle. Axle can stay in the knuckle.
Old Jun 18, 2006 | 06:23 PM
Shiver me timbers.
I used my air gun to take mine off, not that matters to him.
Old Jun 18, 2006 | 06:29 PM
Back from the dead
I disconnected the ball joint to remove the axle instead of disconnecting the strut from the knuckle, not that it matters to him.
Old Jun 18, 2006 | 06:32 PM
Wetballoon's Avatar
I'm glad somebody else noticed.
Shiver me timbers.
I scratched my nuts with my greasy hands while I was trying to get my axle out and it left grease on my shorts, not that it matters to him.
Old Jun 18, 2006 | 06:36 PM
Back from the dead
I decided not to clean off the half pound of axle grease from my blown CV boot before I did the work. I then decided to do the 2nd day of work in my new nike's. I got grease on my new nike's, but I DIDNT CLEAN THEM BECAUSE IM NOT GHEEEEEY!
Not that it matters to him.
Old Jun 18, 2006 | 06:47 PM
Shiver me timbers.
Get ure azz over here and get my passenger's side axle off this fukking bracket!!! Not that that would matter to him of course.
Old Jun 18, 2006 | 06:50 PM
Back from the dead
Give me your gixxer and i'll have it done by tomorrow night. Not that it matters to him.
Old Jun 18, 2006 | 07:09 PM
200kMax's Avatar
u guys are so teh funny..
lots of good advice too..
Old Jun 18, 2006 | 07:35 PM
Fr33way™'s Avatar
Wild for Width
I didn't touch my axle to drop the control arm.
Why are you dropping it anyway? This thread = teh vague.
Old Jun 18, 2006 | 11:19 PM
Guinader's Avatar
I steped really hard on the breaker bar I had and it worked (my neighhood taught me) -> mechanic
Old Jun 19, 2006 | 05:13 AM
vvslavavv's Avatar
I thought you had to take the steering knuckle off to get to the balljoint and remove it? How did you guys do it w/o removing it?
Old Jun 19, 2006 | 05:54 AM
BigLou93SE's Avatar
Dave
Not that it matters to him, but this is how I got my driverside axle nut off. Put a sturdy bar in between the lugs so that the bar gets "pinned" to the grough, keeping the hub still as you torque it.
Old Jun 19, 2006 | 07:32 AM
dgeesaman's Avatar
Maintenance Monster
An open-ended wrench can remove the nut with the axle in place, but since it's not a small nut it's not always easy.
As well, depending on what tool you have for releasing the balljoint from the knuckle, you may need the axle out of the way. If the balljoint has never been removed from the knuckle it can be quite difficult.
As usual, the people from the salt-free states think he's doing it 'wrong'. When you live in a salt-belt state things often work out a little differently.
Dave
Old Jun 19, 2006 | 07:47 AM
BigLou93SE's Avatar
I'm suprised you were able to use a socket wrench on that nut - when I had a cheater bar over my socket wrench, it broke, and I smacked my forehead on my fender. That was a wonderful start to the project.
Old Jun 19, 2006 | 07:49 AM
Shiver me timbers.
Dave
Lot's of salt around here, but I didn't take the axle nut off to replace the control arm. on the balljoint being a b!tch to get out of there.
Old Jun 19, 2006 | 10:10 AM
Back from the dead
Werd... I actually broke my ball joint, but i had new ones in the mail anyway so it didnt matter. Salt is my worst enemy. I can't remove anything from my car with minimal effort.
Old Jun 19, 2006 | 10:21 AM
BigLou93SE's Avatar
Story of my life man...
Old Jun 19, 2006 | 10:39 AM
vettefever5's Avatar
my axle nut was actually the reason (excuse) I went out and bought a compressor and heavy duty impact wrench... after breaking 2 1/2" ratchets and 1 1/2" breaker bar and one socket.
even though we have established that you don't need to take the axle out to get the control arm off, cant you either pop the center cap off from the stock 16" 5 spoke or use the spare tire? I don't remember which I used but I remember the tire was on the car and the car was on the ground which gave me plenty of grip. you might need a 1-2" extension though... it has been a while (thankfully) since I have had to take the axles off.
Old Jun 19, 2006 | 01:59 PM
dgeesaman's Avatar
Maintenance Monster
...not that it matters to him
Old Jun 19, 2006 | 02:44 PM
Fr33way™'s Avatar
Wild for Width
Yes. You can fit the spare and then drop the car. This is how I did it with no assistant to step on the brakes.
Old Jun 19, 2006 | 04:15 PM
200kMax's Avatar
this was the only reason why i assumed you needed to remove the axle nut:
http://maxima.cardomain.com/ride/348507/15
it looked like u didnt need to take apart the axle nut if u had a crescent wrench. so much for me trying to follow others ppl's directions.
not that it matters to u guys ...lol
Old Jun 19, 2006 | 04:20 PM
Back from the dead
hehe we started a mini-catchphrase.
You should always be trying to do the LEAST amount of work..... Sure you could disassemble the knuckle, remove the strut, take off the LCA, remove the sway bar, take out tie rod, and sand/media blast and powdercoat it all, but when all you are trying to do is replace your brake pads, its a little bit overkill
my03maxima
Jul 28, 2024 07:40 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
jaydot901
Sep 29, 2015 01:18 PM
