squeaky squeaky....belt??
Old Jun 18, 2006 | 03:12 PM
willard00's Avatar
never happened in the winter but now that its hot out when i start my car it squeaks loudly for a while (probably 15minutes) then the squeak gets a little quieter but still is noticable. im pretty sure its my surpentine belt (however u spell it)...so my question to you:
does it mean it needs to be replaced? if so, what problems would it cause by not replacing it/how bad would it be if it wasnt replaced?
thanks for the help!
Old Jun 18, 2006 | 04:55 PM
dgeesaman's Avatar
Maintenance Monster
If it's squealed for 15 minutes straight, the belt is def. shot. When a belt chirps on startup or squeals for a few seconds I just tighten it a little bit, but if it squeals much longer I assume the rubber surface is glazed and damaged. You should have the belt-driven accessories checked out to make sure that one of them isn't seizing and causing the problem.
Dave
Old Jun 18, 2006 | 06:02 PM
MIXXMAX's Avatar
Take a quick look at the grooves in the belts. If you see cracks and pieces missing/worn, it's definitley time for replacing. Man, if they squealed for 15 minutes, then something is definitely wrong! There are only 2 belts. Stealership charges less than $100.00 to get them replaced (down here in PA, anyway).
Old Jun 18, 2006 | 08:18 PM
willard00's Avatar
well the belt itself is about $10-20 depending on which belt it is so im thinkin if i do it then ill be doin it myself lol...but thanks ill take a look at the belts in the AM
Black2TheMax
Mar 8, 2005 08:08 PM
SamMan23
Sep 5, 2004 02:05 PM
LiquidhMax
May 18, 2004 11:56 PM
StygianMax
34
Dec 11, 2003 07:26 AM
Keith97gxe
Jul 12, 2003 08:37 AM
